Whats the limit of the TIP?
Old May 8, 2009 | 03:35 PM
  #106
John H.'s Avatar
John H. has a spectacular aura aboutJohn H. has a spectacular aura aboutJohn H. has a spectacular aura about
Originally Posted by BlackHorseTurbo
ASk EVO if they replaced the TC with the upgraded one. IF so, you should be fine.
Modified would be a better descriptive than upgraded. In an application such as this when the factory converter is utilized, there is only one goal - a higher stall speed. To achieve the higher stall speed only two things can be modified - the fins can be bent and/or the stators modified.
What does this do? It increases the stall speed of the converter. It does not make it sturdier or better able to handle increased power.
So what is stall speed? Stall speed in laymen’s terms is the rpm you can achieve while power braking the car. So instead of being able to power brake launch your car at 2k, you can now do it at 3k.
How is this possible? The modified stators/fins allow the converter discs to slip under torque allowing the rpms to rise. Not much unlike slipping your manual clutch.
Pros? By being able to launch your car at a higher rpm you can put the engine higher into the power band and with turbos you can launch under much more boost. Turbo lag will be much lower if nonexistent.
Cons?
1) Heat
Under torque, the converter will slip considerably more than with the stock stall speed. Under torque is not just power braking, but anytime you're at WOT such as a high speed pass. With slip comes heat - a LOT of heat. If you’re not running a large external tranny cooler, you will overheat the clutch bands in your stock tranny. At cruise, your ECU will lock the converter discs together to eliminate slip. Once you start to accelerate or create load such as going up a hill, it will unlock.
2) Less top range power
With slippage, you will be putting down less power. A stock stall convertered car with the same setup will pull on you at highway speeds.
The only reason for a higher stalled converter is dead stop racing. Not something I'd want on a car that did roll racing - especially prolonged and back to back where the ATF will start to boil.
John H
Old May 8, 2009 | 04:58 PM
  #107
_Zac's Avatar
_Zac has a brilliant future_Zac has a brilliant future_Zac has a brilliant future_Zac has a brilliant future_Zac has a brilliant future_Zac has a brilliant future_Zac has a brilliant future_Zac has a brilliant future_Zac has a brilliant future_Zac has a brilliant future_Zac has a brilliant future
Should be a interesting race..
Old May 14, 2009 | 09:30 AM
  #108
007-911's Avatar
007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of
Cons?
1) Heat
John H
John,
Do you know of any companies that make stock stall TC? As for the heat, is there any companies making aftermarket transmission coolers to help deal with the excessive heat?
Thanks,
Vince
Old May 14, 2009 | 09:59 AM
  #109
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
9FF makes a cooler. It's 10K I think. Ouch!
Old May 14, 2009 | 10:28 AM
  #110
TXGold's Avatar
TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !
Glad you're back in business, Todd. Let us hear about the beefy Tip when you get time.
Ryan
Old May 14, 2009 | 10:38 AM
  #111
ttboost's Avatar
You should absolutely have the biggest tranny cooler you can fit, when it comes to that, more is better.
Old May 14, 2009 | 08:46 PM
  #112
John H.'s Avatar
Originally Posted by 007-911
John,
Thanks,
Vince
B&M makes some of the best trans coolers on the market and a lot of very top tier drag racers use them on their cars. You can find them online at Summit Racing from $60 for a passive - $205 for one with a built in fan and thermostat relay.
http://store.summitracing.com/egnsea...rdSearch#rstop
Hookup is relatively the same for all auto cars. You intercept the stock pos "cooler" and add this one inline. If you can't do it yourself, it should cost no more than an hour labor. So with Porsche tax that come to $900/hr? The only issue you'll run into is finding a choice mounting position for it. If you can't find one that gets good air across the cooler mounted vertical, you can always use the fanned one anywhere. Heck, mounted flat right on top of something even. Less than 100%, but loads better than nothing. Don't have more than 2 coolers as it will create a load on the fluid pump. Any fluid capacity to the system you can add is also a good thing for keeping temps down.
John H
Old May 14, 2009 | 09:15 PM
  #113
John H.'s Avatar
Maybe if it was made of platinum. I wouldn't be suprised if it was a rebadged cooler anyway. If they were smart they'd have some Chinese Co remake an existing design at a fraction of the cost, add a custom 996TT fitting, call it their own, profit. Sort of like a couple parts on my car. At least until the Chinese Co starts advertising it on Ebay directly for a lot less. I digress.
John H
Old May 14, 2009 | 09:28 PM
  #114
Ryan
Not quite back in business. Should be up and running in 2 weeks.
Old May 15, 2009 | 12:16 AM
  #115
Shotcaller's Avatar
Shotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud of
So u rebuild the tranny with EVO TC?
Old May 15, 2009 | 05:20 AM
  #116
Harold's Avatar
Harold has much to be proud ofHarold has much to be proud ofHarold has much to be proud ofHarold has much to be proud ofHarold has much to be proud ofHarold has much to be proud ofHarold has much to be proud ofHarold has much to be proud ofHarold has much to be proud ofHarold has much to be proud of
Cons?
1) Heat
John H
Great summary, much thanks
Old May 15, 2009 | 05:23 AM
  #117
Harold's Avatar
John,
Thanks,
Vince
This is my external cooler. Cant remember off hand who it was from, will check. Needed full plumbing that I have now had custom made out of hard piping for durability sake.
Old May 15, 2009 | 07:23 AM
  #118
boca996tt's Avatar
boca996tt is just really niceboca996tt is just really niceboca996tt is just really niceboca996tt is just really nice
would like to know who made that cooler..
Old May 15, 2009 | 09:12 AM
  #119
007-911's Avatar
Have you had any issues with your trans at all? How much power are you putting down?
Old May 15, 2009 | 09:19 AM
  #120
I want that....
