flashed k16 to a K16/16? anyone?
Old May 11, 2009 | 10:58 AM
boca996tt's Avatar
boca996tt is just really niceboca996tt is just really niceboca996tt is just really niceboca996tt is just really nice
I was asked by a cousin of mine if there is a big difference in performance going from a K16 with a flash, DV, and exhaust to a set up like EPL's K16/16 ...and I dont know the answer...I told him Im going to the k24/18g set up..... anyone?
thanks
Old May 11, 2009 | 11:11 AM
vbmw335's Avatar
vbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant future
I went from a flashed k16 to 16g..Big Difference in power ...no comparision.
Old May 11, 2009 | 11:17 AM
boca996tt's Avatar
and a bigger difference from the k16/16 to your k24/18 set up?
Old May 11, 2009 | 11:41 AM
vbmw335's Avatar
I think the difference in k24/18g is more evident only on the top end. In fact below 5000 rpms the 16g feels faster beacause of massive TQ.
Old May 11, 2009 | 11:47 AM
boca996tt's Avatar
thanks for the info I will tell him what you said,,, you think the K16/16 has more TQ then the k24/18? like I mentioned my car is a TIP maybe the k16/16 would be better for my car then the k24/18g then?
Old May 11, 2009 | 11:49 AM
nycsurfer's Avatar
nycsurfer is infamous around these parts
Yes,I have driven cars with all 3 different setup with upgraded fueling,k16/16G is a good bargain if you want to see more power on top-end compare to K16 chipped ,but k24/18G is just another level ,I would do K24/18G if money is no object.
Old May 11, 2009 | 12:17 PM
vbmw335's Avatar
k16/24g?? Are you referring to k24/18g? Boca ...talk to your Tuner and if posibble drive a 16g and 18g cars.
Old May 11, 2009 | 12:33 PM
Seal Grey Matte's Avatar
Seal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to behold
While it won't tell you how each car "feels", you can look at the 60-130 leader board to get a sense of the relative acceleration of each car:
Fastest flashed K16 car - TXGold - 7.92
Fastest K16/16g car - Me - 7.01
Fastest K24/18g car w/out upgraded injectors - Adam Bowles - 6.6
Fastest K24/18g car - Chris Green - 6.08
Old May 11, 2009 | 01:09 PM
nycsurfer's Avatar
Yes,that was a mistype ,corrected
Old May 11, 2009 | 03:17 PM
Alcav5's Avatar
Alcav5 is a jewel in the roughAlcav5 is a jewel in the roughAlcav5 is a jewel in the rough
Am I correct that the X50 package is the K24/16 set up? (+ other stuff)
Having that set up already what does one do if quickness is desired over top end?
I suspect it would be nonsensical to change that set up to a k16/16 (lower) - correct?
Is there a fundemantal difference between type of turbo set up performance results for tiptronic versus manual?
Allen
Old May 11, 2009 | 03:26 PM
vbmw335's Avatar
X50 has K24 Turbos , there is no k24/16.
This is how i would rate different levels of power increments lowest to highest HP.
k16 Turbos (Non x50)
K24 (X50)
k24 Flash
k16/16G Hybrid turbos
K24/18G Hybrid Turbos
Garrett Turbos
The best way for you to make more power since your have X50 (k24 turbos) is K24/18g hybrid turbos. You send your turbo out for conversion and then you can pick up>150 HP.
Old May 11, 2009 | 04:08 PM
PrecisionPorsch's Avatar
PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !
K24 (X50)
k24 Flash
Garrett Turbos
don't forget to pick up a new clutch on your way out
Edwin
Old May 11, 2009 | 05:07 PM
Alcav5's Avatar
Edwin
What do you do if tip tronic? Is upgraded TC mandatory?
Old May 12, 2009 | 11:03 AM
kennyjr748's Avatar
kennyjr748 is infamous around these parts
We just went this route Flash (EPL) to 16/16g hybrids (EPL). We also upgraded the clutch at the same time. The car is definitely faster, but the biggest thing is how boost builds instantly. My wife loves it, which is important because it's her car! I pushed for the 24/18 setup, but was worried about putting in a clutch that she wouldn't like. Finally decided to play it safe and went with the more conservative route. Bottom line is that she's happy... which makes me happy!
Old May 12, 2009 | 11:47 AM
Tony@epl's Avatar
Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !
Glad to hear she's enjoying the new power!
