Correcting rear camber.. the right way to do it?
Old May 13, 2009 | 07:21 PM
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
I have been wearing out my tires VERY quickly and at $450 a pop I am now thinking of going with a less aggressive alignment. My question is what is the best way to add positive camber to the rear wheels? Dog bones (upper control arms) or OEM GT3 adjustable lower arms?
Are the GT3 lower arms made to lessen camber only or by installing them?
Also, I was told to upgrade to adjustable toe links. Are these necessary to get the car aligned to spec?
Old May 13, 2009 | 07:35 PM
heavychevy's Avatar
You should not have to add mods to your car to get less camber. Who is aligning the car and what are your current alignment settings? Also where are the tires wearing too fast, inside edge?
Your JIC's should have come with pillow ball upper mounts that allow camber adjustment in the rear. All you need is for those to be setup to a more friendly setup. Toe can also be adjusted without mods, it's just tougher.
Old May 13, 2009 | 07:44 PM
dgreen78's Avatar
Cantrell Motorsports in Kirkland is aligning the car. They are a very good shop and they recommended I go with the upper dog bones. The tires are wearing very fast on the inside edges. I was unaware that the JIC rear had adjustments for the camber?
Old May 13, 2009 | 08:30 PM
mikerosi's Avatar
mikerosi is a jewel in the roughmikerosi is a jewel in the roughmikerosi is a jewel in the rough
If your car is lowered, you reach a point where the factory eccentic camber adjustment will not allow any more positive camber. So what I did was add the upper dogbones out at a 1/4 inch and then you can run less camber and better tire wear. Most people are running WAY too much negative camber. BTW Carry Eisenlohr told me that and I am sorry if I misspelled his name.
Old May 13, 2009 | 08:52 PM
Red 9's Avatar
Red 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond repute
Are you talking normal road use --or track?
Old May 13, 2009 | 08:54 PM
dgreen78's Avatar
It is my DD (15K a year or so avg.) and I do about 3-5 DE per year.
Old May 13, 2009 | 11:44 PM
heavychevy's Avatar
Why not raise the car up a tad? Are you running GT2 ride height specs?
Old May 14, 2009 | 12:40 AM
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
I don't think it comes for the rears Heavy... I'm sure it's fronts only
Old May 14, 2009 | 12:43 AM
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
On my car, in the rear I have the Agency Power upper control arms and lower toe link, with stock lower control arms. When I have the car aligned, I have them first set the track alignment (-2.25 deg, stock toe-in), then reset it to the stock street setting. I write down the changes, e.g, 1.5 turns CW on front control arm, 0.75 turns CW on rear control arm, 0.5 turns CCW on toe link. It is then very easy to go back and forth between the two settings.
I get very even tire wear on both the street and the track.
Jon
Do you know what Camber settings you are currently running for the car Don?
Old May 14, 2009 | 05:47 AM
FAST FWD's Avatar
Was this intended for me?
Anyway, I run the absolute stock alignment on the street. I don't recall the settings offhand, but you can find them easily.
On the track I use stock toe and -2.25 deg camber in the rear, -2.5 deg camber in the front with maybe 0 deg toe, or even a touch positive. I have GT3 lower control arms in the front, and need 14 mm of shims to get that much negative camber.
Old Jun 9, 2009 | 11:39 PM
jgogo's Avatar
jgogo is infamous around these parts
I am having the same issue with my lowered 2001 911 Carrera. Will the adjustable (dog bones) fix the camber issue by themselves?
Old Jun 10, 2009 | 06:32 AM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
My car is alligned at GT2 ride height and specs...While alligning the car i understood that with stock control arms(rear)the factory eccentrics reach their limits in order to get the desired camber...However i was slightly in specs for rear camber...if somebody goes below GT2 ride height,he should definetely use some kind of adjustable control arms in order to reach desired camber...
Old Mar 20, 2011 | 03:50 AM
Kevganzon's Avatar
Kevganzon is infamous around these parts
Sounds to me if im lowered on 1" springs all i need is upper control arms if i just want to get less negative camber?
Old Mar 20, 2011 | 09:33 AM
FAST FWD's Avatar
Correct. Most people replace the rear toe link and put in locking pins to remove the factory eccentric camber adjustments.
