turbo boost vs. diverters
Old May 14, 2009 | 10:35 AM
kosmo96's Avatar
kosmo96 is infamous around these parts
I have a stock 04 996 turbo. My boost now peaks at 7 and it used to peak at 8. If my oem diverter valves are beginning to fail does it cause a drop in my boost or an increase over previously normal levels? Thanks for your advice.
Old May 14, 2009 | 11:19 AM
kwerks's Avatar
kwerks has a spectacular aura aboutkwerks has a spectacular aura aboutkwerks has a spectacular aura about
If your seeing .7 where you always see .8 (same throttle position etc..) especially on a hot engine. Then chances are that your DV are leaking boost. I had this issue recently where it was .8 then .7 then one morning I could not go over .5. Changed out to AWE units and problem solved. I am now back to .8bar. Once you see the factory units you will ask yourself did that really come from a porsche or better why would they stick such POS units in.
Old May 14, 2009 | 11:20 AM
Tony@epl's Avatar
Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !
I see you are in CT. Let me know how we can help!
Jul 29, 2019 11:13 AM
BlackMarketRacing
Dec 8, 2015 01:49 PM
oddjob142
Aug 19, 2015 12:27 PM
ECS Tuning - VW
Aug 19, 2015 08:58 AM
