AEM Methanol Install & 24/18G dyno results
Old Jul 15, 2010 | 01:54 PM
  #46
str8blst's Avatar
str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !
Originally Posted by contigo
Something aproximate using the car hard (racing), something in miles or example re fill everytime you refill gas? Or every half a tank?...
I have Meth installed on my S4. It uses my windsheild washer reservor which is probably around 3 or so gallons. I have the Meth set to spray at 15+psi and I need to refill once a week or more depending on how agressive I drive. I would imagine on our cars you would want at least a 5 gallon reservor and possibly more if you car lives much of it's life at/on boost.
As others have said though... much of it will depend on how you have the controller set. But the obvious answer is more time on boost= less meth...
Old Jul 15, 2010 | 02:02 PM
  #47
ttboost's Avatar
As others have said though... much of it will depend on how you have the controller set. But the obvious answer is more time on boost= MORE meth...
Fixed...
Old Jul 15, 2010 | 02:25 PM
  #48
contigo's Avatar
contigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant future
it is not a matter of cost here but meth is hard to get here as it is used in our country for other ilegal uses so they only sell very little per month and with ID on hand
  #49
str8blst's Avatar
Originally Posted by ttboost
Fixed...
Yup... you got what I meant though...
Old Jul 15, 2010 | 02:27 PM
  #50
ttboost's Avatar
Oh yeah, Right!!! Maybe you better stick to windshield washer fluid!!! Can you get that there!!!
Yup...
Old Jul 15, 2010 | 03:42 PM
  #51
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
For anyone that is interested, I have the kit for sale ($200!) so PM me if you are interested. It works great and is and easy 40+ HP!
Old Jul 15, 2010 | 03:44 PM
  #52
ttboost's Avatar
Your car done yet Don?
Old Jul 15, 2010 | 03:45 PM
  #53
dgreen78's Avatar
Yup, have 1K on the motor now and going to turn the boost up and tune it in next weekend!
Old Jul 15, 2010 | 03:48 PM
  #54
ttboost's Avatar
Sweet!!! Start a new thread, if you haven't already!!!
Old Aug 12, 2010 | 02:20 PM
  #55
ttboost's Avatar
Well?
Old Aug 12, 2010 | 03:20 PM
  #56
dgreen78's Avatar
Well?
Dyno'd the car today on pump/meth and apparently the fuel pressure is dropping fast at around 530whp with my new Aquamist methanol kit
Going to put back the 044 in the rear and turn it up next week. I didnt build my motor and put 3076s in to have the same power as I did with 24gs and a 5 bar
Old Aug 12, 2010 | 03:24 PM
  #57
ttboost's Avatar
Dynoed the car today on pump/meth and apparently the fuel pressure is dropping fast at around 530whp with my new Aquamist methanol kit
You just have the one pump in the tank, no "booster"?
Old Aug 12, 2010 | 03:46 PM
  #58
dgreen78's Avatar
Nope, took it out when I did the meth kit last time. With all the negative comments about installing a rear inline pump I decided to remove it at my power levels (24/18g).
Are you running a booster pump inline with your setup?
Old Aug 12, 2010 | 04:00 PM
  #59
Blockhed's Avatar
Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !
hey don keep us posted I'm curious of your results.
Old Aug 12, 2010 | 04:39 PM
  #60
ttboost's Avatar
Nope. All stock stuff except 58lb injectors...Tony and I had a conversation the other day about the benefit of an 044 vs stock pump...
Me too...
