2004 996tt GT700+ NO BOOST
Old Jun 19, 2009 | 02:01 PM
Technological's Avatar
Technological has a spectacular aura aboutTechnological has a spectacular aura aboutTechnological has a spectacular aura about
I did a pretty deep search and couldn't find anything relative.
Car in our workshop has a GT700 kit plus intercoolers, tbody, and y-pipe. Original build was a year ago. Ran like a top until this week.
Car builds absolutely ZERO boost. Has a CEL for major evap leak, but we have traced that to a split in the charcoal canister. Shouldn't affect power.
No smoking, no noises, runs perfectly. Other than the fact that it goes about as well as a C4S. Cluster gauge reads 0.0bar. PST2 confirms that reading.
Actuators appear to be intact, moving freely. Nothing obvious on the motor as to problems.
Customer says nothing happened prior to the loss of power, it just happened.
Have contacted EVO for advice, figured I would increase my odds a bit.
Thoughts?
Chris
Old Jun 19, 2009 | 02:12 PM
MBailey's Avatar
If turbos working there must be a boost leak. I would check turbo impellers, if ok then pressure up system and look for leaks. Although not seen a leak that large without a light.
Old Jun 19, 2009 | 04:02 PM
168's Avatar
168
168 is infamous around these parts168 is infamous around these parts
I had this identical problem last spring. The dealer checked for leaks, ECU problems, and also if the car was in valet mode.
Mine ended up to be a piece of metal from one of the headers that had come off, and got stuck in the turbo, and for some reason, the wastegate on the other turbo was not adjusted properly, which resulted in zero boost.
When I spoke to EVO, first thing they suggested to check were the turbos.
Don't know if this is of any help in your situation though, but it sounds similar.
Old Jun 19, 2009 | 04:12 PM
could be anything.... start with a boost leak at the turbos... inspect the turbos wheels...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jun 19, 2009 | 04:35 PM
Evolution MotorSports's Avatar
Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !
Thoughts?
Chris
Check the wastegate rods. Also, you can remove the air feed ducts to the inlet side of the turbos and inspect the compressor wheels. You can also spin the compressor wheels to see that they spin freely. Start there and let us know
Evolution MotorSports | www.evoms.com
EVOMSit - intelligent tuning |www.evomsit.com
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
Home of the Worlds Fastest 997TT Porsche(s)
997TT Standing Mile = 234.6 MPH
997TT Standing 1/2 Mile = 217.09 MPH
Fastest 1/4 Mile = 9.29 @ 172.7 MPH
60-130 MPH Time = 3.28 Seconds
Old Jun 19, 2009 | 07:41 PM
jags911tt's Avatar
jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !
Hope its not the turbos...but if it is Ive got a pair that Im selling
Old Jun 19, 2009 | 08:56 PM
jimmer23's Avatar
jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !
Same thing happened to Powell about a year ago. Turned out his compressor wheels ate the rubber reducer rings on both sides and got all chewed up. Hope this isn't the case with yours, but sounds like it.
Old Jun 20, 2009 | 10:19 PM
Monster231's Avatar
Monster231 is infamous around these parts
Any Updates
Curious as to what the verdict was
Old Jun 20, 2009 | 10:50 PM
We're pulling the turbos on monday morning. Start with the exhaust and see if we can see anything from there.
We shall see. I'll post up the findings for sure.
Thanks for the ideas, although they all sort of point the same way I was hoping they wouldn't! hehe
Old Jun 21, 2009 | 07:48 AM
FWIW, it is much easier to pull the air inlet ducts to inspect the turbos.
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
Old Jun 21, 2009 | 11:06 AM
haha, you would be correct. It's saturday i flick a little switch in my head and TRY and not think car stuff on the weekends.
Fadi
Aug 17, 2018 05:16 PM
MtnTempo
Sep 14, 2015 06:49 AM
johnny.dangerous
Sep 11, 2015 02:39 PM
Yogi911
Sep 9, 2015 08:20 PM
sparks
Sep 8, 2015 03:03 PM
