Throttle cut question....
Old Oct 30, 2004 | 02:13 AM
K24madness's Avatar
K24madness is infamous around these parts
At what boost levels does the ECU cut the throttle angle? I belive it is 1.35 bar. Could someone confirm this.
THIA
Old Oct 30, 2004 | 02:27 AM
StephenTi's Avatar
StephenTi is infamous around these parts
I have a feeling it's more than simply boost-related... may have to do with MAF sensor voltage as well (air flow capacity), and perhaps other parameters. Doing a simple experiment in the next few days to see if it's true.
Old Oct 30, 2004 | 02:32 AM
K24madness's Avatar
98% sure its only MAP sensor related. If the MAF maxes out the ECU goes full duty cycle on the injectors.
Old Oct 30, 2004 | 11:52 AM
cjv's Avatar
cjv
Moderator
1.3 bar.
Old Oct 30, 2004 | 12:07 PM
StephenTi's Avatar
Trust me... boost is not the only factor... I've seen and experienced the over-boost tb failsafe at lower than 1.3 BAR.
Old Oct 30, 2004 | 10:51 PM
PorschePhd's Avatar
The TB will close down in many situations. It is not just listed for boost. It is a protection and if anything in the motor goes way out of parameter it will close the throttle body to eliminate boost. It is telling you it is not happy about something. So while most cases are an over boost it does not have to be.
Old Oct 31, 2004 | 06:56 AM
K24madness's Avatar
Yes I agree there other reasons that the ECU will cut throttle angle. Most often it is overboost that causes throttle cut to protect the motor. Thanks for your input guys!
30vQuattro
20
Dec 4, 2015 05:26 PM
007 Vantage
Oct 8, 2015 08:35 PM
km90265
Sep 27, 2015 10:57 PM
PelicanParts.com
Sep 25, 2015 03:17 PM
