annoying whine???
Old Nov 1, 2004 | 01:50 AM
vin457d's Avatar
vin457d is infamous around these parts
annoying whine???
Question for you techies? My 04 TT has developed a whine sound coming from the engine. I only hear it at idle. Do any of you have any idea what this could be?? I am making an appt with service but it will be a few days out....
Thanks,
Old Nov 1, 2004 | 02:13 AM
SilverTTCab's Avatar
Senior Member
SilverTTCab has much to be proud ofSilverTTCab has much to be proud ofSilverTTCab has much to be proud ofSilverTTCab has much to be proud ofSilverTTCab has much to be proud ofSilverTTCab has much to be proud ofSilverTTCab has much to be proud ofSilverTTCab has much to be proud of
i hear that too.
only intermittantly, when i'm not on the throttle....
hope it's not anything bad!
Old Nov 1, 2004 | 02:56 AM
JP Schnitzer's Avatar
JP Schnitzer is infamous around these parts
If it goes away when you depress the clutch, then it is some clutch related valve that tends to be noisy....mine does it too. I don't think it is anything to worry about.
Somebody on the board knew about this and what it was...???
Old Nov 1, 2004 | 03:34 AM
carbonissimo's Avatar
carbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud of
My EX used to whine.
Old Nov 1, 2004 | 04:21 AM
Rob's Avatar
Rob
Rob is a glorious beacon of lightRob is a glorious beacon of lightRob is a glorious beacon of lightRob is a glorious beacon of lightRob is a glorious beacon of light
If you do a search, you'll find some discussion about this noise which is heard near/at idle and goes away when pushing the clutch pedal in. I have it, too. I took the car to the dealer and, in a nut shell, they told me it's the Nitrogen Valve in the hydraulic system which operates the clutch assist and the power steering. Evidently, it can sometimes vibrate under pressure and make the noise. The valve is hard to get to (engine out is easiest) and the replacement valve may do the same thing, so it's basically a "live with it thing". If it's any consolation, mine has been doing it much less often, now. I have about 15K miles on the car.
Old Nov 1, 2004 | 04:39 AM
WARDHOG's Avatar
WARDHOG is infamous around these parts
Did you step on her too, to stop her whining?
Old Nov 1, 2004 | 09:49 AM
RBenedon's Avatar
RBenedon is infamous around these parts
I noticed the same thing, a whine or whistling sound at low RPM that goes away when I depress the clutch coming to a stop. Have service appt on 11/2 - so I will post the solution here..
Richard
Old Nov 1, 2004 | 09:55 AM
VWH3RD's Avatar
VWH3RD is infamous around these parts
I have the same FRIGGEN noise in my 04 cab. It seems to whine when I am in 2nd or 3rd gear , off the gas and the rpm's get low.
It goes away as soon as I depress the clutch!
It drives me insane!
Old Nov 1, 2004 | 10:07 AM
golfnut's Avatar
golfnut is infamous around these parts
I get the exact same thing with mine. Usually it's not too loud but other times it's so loud that I look in the rear view mirror thinking there is a cop coming after me with a siren.
Old Nov 1, 2004 | 10:30 AM
Headdoc's Avatar
Headdoc is infamous around these parts
I got it too. Usually happens when I am coming to a stop or slowing down and goes away when I depress the clutch. It is especially noticeable when the top is down.
Old Nov 1, 2004 | 10:31 AM
vin457d's Avatar
If someone gets a service appt before I do, please post your findings, it will be good to get a heads up on the cause. I am going to call my dealer tomorrow and get a service appt but, my dealer is usually a week or two backed up so I'll let you know as soon as I find out from my end...
thanks,
Old Nov 1, 2004 | 01:42 PM
msindi's Avatar
IT IS NORMAL...unfortunately
Old Nov 1, 2004 | 01:54 PM
TUUNER's Avatar
TUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant futureTUUNER has a brilliant future
Yup. I get the same noise...especially when I am in 2nd gear and I start to really slow down...push the clutch in and it's gone.
And here I thought I was the only one!
T
Old Nov 1, 2004 | 02:29 PM
Rave TT's Avatar
Happy Now?
Rave TT is a jewel in the roughRave TT is a jewel in the roughRave TT is a jewel in the rough
My ex-wife use to have an annoying whine.
Old Nov 1, 2004 | 05:17 PM
oak's Avatar
oak
The conclusion is that this noise is common/normal. FWIW Dan the SA at Pacific Porsche also told me the honking sound from the DV's was normal. Even though it's common, it shouldn't be this audible. At times the squeel can sound excruciating. Sound doesn't seem to be consistant with my turbo, every time I had taken it in to have the dealer look into it the sound wasn't quite audible.
I posted about this noise last year. Had the tech at Pacific Porsche look into it, although while at the dealereship it didn't seem to make the noise.
