CEL codes p1411 and p0410, need a diagram/picture of secondary air inj. pump!
Old Jul 15, 2009 | 08:15 PM
tvr-4's Avatar
tvr-4 has a reputation beyond reputetvr-4 has a reputation beyond reputetvr-4 has a reputation beyond reputetvr-4 has a reputation beyond reputetvr-4 has a reputation beyond reputetvr-4 has a reputation beyond reputetvr-4 has a reputation beyond reputetvr-4 has a reputation beyond reputetvr-4 has a reputation beyond reputetvr-4 has a reputation beyond reputetvr-4 has a reputation beyond repute
So,
The notorious "Secondary Air Injection" CEL came on the other day. The pump runs, so it should be one of the few remaining bits:
1) Electric change-over valve
2) Air change-over valve
3) Boost or line leak
4) Blockage in one of the lines/vacuum lines
I honestly don't think it is a blockage and from what I can see, nothing irregular with the vacuum lines, the car runs fine and has only 28,000 miles.
Does anyone have a picture of where 1) and 2) sit in the engine bay?
I have the detail diagram of the air injection system, but I can't tell where the pieces are in ralation to the engine parts, and I want to avoid taking half of the enigine bay appart if at all possible.
Thanks for help!
TK
Old Jul 15, 2009 | 08:23 PM
raineycd's Avatar
See if page 51 helps you locate these:
http://www.porsche.com/all/media/pdf...6T_KATALOG.pdf
Old Jul 15, 2009 | 08:24 PM
adam699's Avatar
adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !
This should help you out:
File Type: pdf
File Type: pdf
Old Jul 15, 2009 | 09:21 PM
slvr99M3's Avatar
slvr99M3 is infamous around these parts
p codes
It should be the diverter valves causing the light to turn on due to bieng closed or open during the wrong time.
Old Jul 15, 2009 | 09:31 PM
roadsterdoc's Avatar
Member
roadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to behold
One of the diverter valves is bad. Replace them both with aftermarket ones and kiss those 2 codes goodbye forever.
Old Jul 15, 2009 | 09:51 PM
raineycd's Avatar
If is the DV's just saw Steve Harris has a pair of Forge DV's for sale in the marketplace forum.
https://www.6speedonline.com/forums/...forge-dvs.html
Old Jul 16, 2009 | 10:50 AM
rolfjahn's Avatar
rolfjahn is a splendid one to beholdrolfjahn is a splendid one to beholdrolfjahn is a splendid one to beholdrolfjahn is a splendid one to beholdrolfjahn is a splendid one to beholdrolfjahn is a splendid one to beholdrolfjahn is a splendid one to behold
Originally Posted by tvr-4
So,
Thanks for help!
TK
I know this problem well and have helped more than 1 6speeder already.
It's has been 3 for 3 on the (voltage supplied/mechanical) check valves but now would be a great time to change your DVs.
It's really straight forward but requires some mechanical abilities and tools.
Read this post https://www.6speedonline.com/forums/...ml#post2333373 and if you have more questions PM me. Rolf
Old Jul 17, 2009 | 06:25 PM
tvr-4's Avatar
Guys,
thanks a bunch, exactly what I was looking for.
Rolf (?),
great help, and great guidance on lowering the engine - I keept thinking, there is no way I can get to all this in the back, and you are right, might as well replace both once in there.
I need to do my 30k in 1900 miles, so I may just wait and do it all at once!
Thanks again guys :-)
Old Jul 17, 2009 | 07:26 PM
raineycd's Avatar
Hey, you going to be in Oxford in a week?
Old Jul 17, 2009 | 08:25 PM
tvr-4's Avatar
I plan on it, are there any other people coming from south? Maybe we can caravan together from Cincinnati - it is about 40 min from here.
Old Jul 17, 2009 | 08:42 PM
raineycd's Avatar
Yeah, I think there is going to be a group. I will keep you posted on times, etc.
Old Sep 11, 2012 | 11:45 AM
Tim Euler's Avatar
Tim Euler is infamous around these parts
I just stumbled on this series of posts. This is exactly what I am looking for but for a 2000 911 (996) C2 Cab. I am looking for those same pdfs that show the vacuum routing. would you have .pdfs showing exactly the same info but for my non turbo car?
Thanks in advance
Tim
Jul 29, 2019 11:13 AM
COBB Tuning
Mar 29, 2016 09:26 PM
The Oss
Aug 24, 2015 08:19 PM
oddjob142
Aug 24, 2015 05:49 PM
