New Turbo Owner -- CEL Light
Old Mar 30, 2009 | 08:14 AM
Double Trouble's Avatar
Double Trouble is infamous around these parts
Hello all. My name is Ben and I just bought a Lapis Blue '01 Turbo 6-speed. I've owned it for 2,000 miles, including a 1,500 mile trek from Santa Barbara where I bought it, home to Dallas, TX where I live. I bought it with 32,000 miles on the odo, and now have just a hair over 34,000 miles on it. It's my new daily driver, and I absolutely love it.
Driving home last night, I got a check engine light on the highway that says to immediately take the vehicle to a workshop. Is there anything common about these cars going wrong at about 35,000 miles that I should be aware of? Is this a light for routine maintenance, or is it likely that something is actually wrong? I'm the third owner of the car, and it has a Carchex aftermarket warranty, but I'm concerned and curious to know what kind of preventative maintenance I need to perform on this car to keep it running for years to come.
Thanks for input,
Ben
Old Mar 30, 2009 | 08:16 AM
PrecisionPorsch's Avatar
PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !
Thanks for input,
Ben
Ben,
Did you recently fuel up before the CEL went on?
Edwin
Old Mar 30, 2009 | 08:21 AM
I fueled up that same day with 93 octane. I'm at about 1/2 tank now. I drive the car a lot
Can fuel throw a CEL?
Also, my oil pressure guage on the rightmost side reads at 5 during normal operation. Is this normal?
Ben
Old Mar 30, 2009 | 08:23 AM
Ben
Ben,
I fueled up and drove around and then the CEL came on. People have had problems with the CEL coming on if you don't close the gas cap tight enough. I'd recommend unplugging the battery, give then fuel cap a few more turns, wait 10 mins or so and then trying it again and see if the light comes back on
Edwin
Old Mar 30, 2009 | 08:25 AM
Thanks for the advice. The car seems to be operating normal, so when I got the CEL I got kind of concerned. I love driving the sucker, it's a blast. I'm just hoping that there isn't anything wrong with it...
Ben
Old Mar 30, 2009 | 08:28 AM
Ben,
When the CEL came on, was it blinking or just came on and stayed on? Check the manual too, I think they specifically mention the fuel cap issue
Edwin
earlymidlifecri's Avatar
earlymidlifecri is infamous around these parts
Ben
The oil pressure will read 5 when you are on the throttle. When the car is fully warm, and your foot is off the gas, the oil pressure should be between 2 and 3. When that is happening, you know the engine is warm, and it's ok to boost.
Old Mar 30, 2009 | 08:36 AM
Thanks for the info guys. As far as the cel light, it just came on and has stayed on. No flashing or blinking.
Do these cars need to sit turned on after being driven for a while? Is it unsafe to go into boost with the engine not fully warmed up?
Thanks again,
Ben
Old Mar 30, 2009 | 08:55 AM
Ken's Avatar
Ken
Ken is a jewel in the roughKen is a jewel in the roughKen is a jewel in the roughKen is a jewel in the rough
Thanks again,
Ben
If it's not blinking, you're probably ok. Disconnect the battery for 10 minutes and it will clear the CEL. See how long it takes for it to come back on - if it is immediate, take it to a garage to get the code read. Then you can make your decision if it's a problem.
Do you have an after market exhaust?
Old Mar 30, 2009 | 09:00 AM
Thanks again,
Ben
I try to keep it under 3500 rpm and not engage boost before it's warm. The turbos can get really hot, and if oil can not circulate easy, i.e., it's cold, you will cause a problem. Likewise, if you have engaged the turbos a lot during a drive, you need to drive the car slowly and let it idle for a minute (some here will say two minutes) before turning it off, so the oil doesn't bake on the turbos. Enjoy!
Old Mar 30, 2009 | 09:01 AM
The car is 100% stock to the best of my knowledge with a recent 30,000 mile service done, and fresh oil. Is the battery disconnect you guys are referring to in the front of the car next to the brake fluid?
Thanks,
Ben
Old Mar 30, 2009 | 09:13 AM
Thanks,
Ben
Ben,
Yes it is. Do you have an owner's manual?
Edwin
Old Mar 30, 2009 | 09:14 AM
Ken's Avatar
Ken
Thanks,
Ben
Under the hood in the center - big lid. Do NOT close the lid until you reconnect. Remember the latch is electrically opened (I learned the hard way)
Old Mar 30, 2009 | 09:15 AM
Ouch!! How'd you get it open?
Edwin
Old Mar 30, 2009 | 09:19 AM
smokinxtreme's Avatar
smokinxtreme has a spectacular aura aboutsmokinxtreme has a spectacular aura about
my cel came on last week and found that one of my sensor went bad..........problem solved.
