Revo
Old Jul 20, 2009 | 03:45 PM
alex55's Avatar
alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !
Revo
who is using Revo software for the 996tt ?
can someone give a feedback about them ?
thanks !
Old Jul 20, 2009 | 04:17 PM
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
Shoot a PM to Robertp, he's got one and is extremely fast. He can definately tell you the specs.
Old Jul 20, 2009 | 05:09 PM
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
Revo is one of the best out of the box ECU programs on the market. You can adjust many parameters and lock them in to specific environments , fuel types or performance needs.
If you purchase Revo get the select plus that allows data logging.
I attached the PDF file that goes with the select plus package.
Old Jul 20, 2009 | 08:40 PM
drh's Avatar
drh
drh has a spectacular aura aboutdrh has a spectacular aura aboutdrh has a spectacular aura about
I have the Revo upgrade.
In stock mode the car drives normal.
In performance mode it is certainly faster, BUT I notice a significant jump every time the variocam shifts modes. It is much more pronounced that stock to the point where is it very annoying when cruising at freeway speeds or any speed where I am below 3800-4000 rpms. My co-pilot even mentioned that she noticed this on our last club drive.
FWIW, I always put the car back into stock mode for regular driving because of what I described above.
I've also been told by a reputable source that my stock file is gone and replaced with the Revo version of stock. I was not made aware of this prior to the install, and I'm not sure if it really matters.
My 0.02
Old Jul 20, 2009 | 09:44 PM
robertp's Avatar
Mine did the same until I created a custom setting. I do not use the Revo performance setting. I have my variables locked in and now the car performes very well. I also only run MS VP 109 but this shound not make that much of a difference. I suggest you hook your laptop up to the ODBC and play around with the variables and fine tune the setting to your liking. It took me 1000 miles of driving to fine tune the file but the result is worth the work.
Old Jul 20, 2009 | 09:47 PM
drh's Avatar
drh
What did you change to eliminate the variocam jump?
Old Jul 20, 2009 | 09:56 PM
MoeMonney's Avatar
MoeMonney is infamous around these parts
I have a friend here that has REVO on his 996TT and he loves it. He had the original performance tune then changed it soon after to boost 8 timing 4 and now the car is very fast and confortable to drive for him. He was very satisfied. The boost and timing and other setting should be adjusted to each car and its enviroment and mods.
Old Jul 21, 2009 | 12:05 AM
slvr99M3's Avatar
slvr99M3 is infamous around these parts
Revo tune
Ive personally installed revo software in many 996tt's and all of my clients have been happy with the all around power without any warnings or issues!
Old Jul 21, 2009 | 02:42 AM
alex55's Avatar
thanks guys !
Old Jul 21, 2009 | 08:07 AM
robertp's Avatar
Mine is set to the car and mods and you will have to do the same. start by looking at what the performance setting are set to and go from there. Take your time, write down the likes and dislikes of every combination and you will fine tune your Revo to your mods.
Old Jul 21, 2009 | 09:48 AM
tom kerr's Avatar
I started with REVO and also had good results. I think the most important thing is to have whoever works on the car use what they are most familiar with. the program is only as good as the people servicing the car. once you start having troubles and no tuner is around you are out of luck.
maroli
Sep 15, 2015 07:07 PM
integrate
Merchandise For Sale / Wanted
Feb 2, 2006 02:34 PM
Chordate
May 25, 2005 01:28 PM
