Spoiler not working at all ! Durametric code 9150 please help
Old Jul 21, 2009 | 03:59 PM
gearhead's Avatar
gearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond repute
hey guys just got my new to me 2001 black on black 996 tt with 19k miles on it. but for some reason my spoiler won't move at all. You push the button on the dash and you get the dreaded light. Tried listening for any hydraulic pump whine (like its trying to lift it) and hear nothing. It doesn't seem like its leaking or corroded. My durametric tool came up with 9150 spoiler control status: present. Not sure what that means but any help will be greatly appreciated. Also my key remote is not working, I know this is a common problem but i've tried everything (turning battery around trick, trying new battery etc.) light on remote works fine and if i lock the car with the key I can turn on the alarm system. So I am confused. I await patiently for your response.
Old Jul 21, 2009 | 05:13 PM
wross996TT's Avatar
for the spoiler...fuse (D7), relay or microswitch (or the drive is faulty). For the key, neither key works? When you activate the remote, does it flash and what does the dash light do? Most likely it needs to be re-paired with the immobilizer...which you need PST2 or PIWIS. After you get it to work there is also a TSB for your remoteRemote TSB
Old Jul 21, 2009 | 10:04 PM
911TurboRules's Avatar
911TurboRules has much to be proud of911TurboRules has much to be proud of911TurboRules has much to be proud of911TurboRules has much to be proud of911TurboRules has much to be proud of911TurboRules has much to be proud of911TurboRules has much to be proud of911TurboRules has much to be proud of
My spoiler is dead too. It's the second time! The first time I was leaking hydraulic fluid until it didn't raise anymore. I bought a used wing and took the motor off of that and put it in my car. That lasted about a year. It's a well known problem that the motor breaks on the rear spoiler. The problem may be in a faulty micro-switch (it's connected to the right cylindrical motor), leaky (it's possible all the fluid is gone) hydraulic fluid or failed motor(s).
I'm going with a fixed GT2 wing!
Good luck.
Old Jul 22, 2009 | 12:22 AM
Yves's Avatar
Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !
Mine died and i'm not even getting a fault code. Nothing. I only recently noticed it doesn't raise anymore above 70mph.
Old Jul 22, 2009 | 04:30 AM
You're luckier than me. The fault code popping up while you're driving is really annoying!
Old Jul 22, 2009 | 08:59 AM
Technological's Avatar
Technological has a spectacular aura aboutTechnological has a spectacular aura aboutTechnological has a spectacular aura about
We've had a rash of wing problems in our shop lately. Just last week two cars required motors. We have replaced a few hydraulic rams, and fixed a few leaks. They aren't fun to diagnose either.
Old Jul 22, 2009 | 10:01 AM
996TWINS's Avatar
996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute
911TurboRules is this an "easy" DIY swap? I was looking into the same thing. Sounds like it is probably less $$$ in the long run.
Old Jul 22, 2009 | 06:53 PM
Supposedly it's just getting the decklid and wing, having a shop paint it and then it's a direct bolt-on to the car. Un-bolt the decklid, undo the wiring, and bolt on the new decklid and reconnect the wires. You either short out some wires in the factory harness to stop the warning lights from popping up or buy a new harness that does this (part number 996 612 070 30). I think it should be easier than replacing the motors (although that wasn't too bad).
Check out this link:
https://www.6speedonline.com/forums/...ixed-wing.html
Paul
Old Jul 23, 2009 | 09:30 AM
996TWINS's Avatar
Thank you Paul
Old Jul 23, 2009 | 06:57 PM
No problem. Good luck with your wing!
3WDistributing
31
Oct 27, 2017 01:26 PM
PorscheEnvy
Aug 26, 2015 10:15 PM
oddjob142
Aug 24, 2015 05:49 PM
silver86
Cayenne 958
Aug 21, 2015 03:08 PM
