two 997TT's pick on a lower powered 996TT Cab
This video was taken last summer before I installed the JIC exhaust.
The three cars are as follows.
1. 2007 997TT 700HP Protomotive with 100 and VP 109 mix
2. 2007 997TT 650HP BBI built with lots of TQ
3. 2005 996TT Cab 550HP???? Robert Built.
http://www.youtube.com/watch?v=LwRDKkbIxxo
He has the most TQ. Very fast car but no race gas on that run. Since then he has made a few more modifications and dynoed at 820TQ.
As far as experience, he has that covered too. He tracks the car and own a F430.
At the time of the video; Revo Flash, ATS triple clutch and LWFW and DV's. Since then I added a Titanium JIC Exhaust which really makes a difference.
Ok, if he has 650HP and is an experienced driver, how does he not even pull along side of you in your 550HP 996tt .... 100 HP and Experience should be a no brainer, this is like saying 1+1= 3.
I know your car is quick for its limited mods, but if what your saying about the red car and the driver is true, maybe he mis shifted? spun tires? Has to be some type of explanation why 100 HP cant at least pull a nose, i mean you dont even see him in the vid until you let off and he cruises by.
Id be at BBI's doorstep the next day with smoke coming out of my ears haha
He is not the only one I do it too. I have video of twenty different cars (even an LP640) who is behind me from 10MPH to 130MPH. I did race him 5 times that day.
I did forget to mention that I only run MS VP 109 and the car has a custom (Revo) tune to maximise that gas. I will post the lambo video.
The more power to you! The MS VP 109 was just a little hint you left out ha..... have you ever put your car on a dyno with the MS VP 109 and got actual #'s? Maybe your making more power then you think, and your closer to these higher HP cars then you thought?
No dyno, but since I am running stock K24's, they have an HP limit that is not even close to most of the cars I run with.
Since when does Barrister have 820 wheel tq? As far as i know, his mods are flash, exhaust, ipd plenum, BBI underdrive pulley. Stock intercoolers, stock turbos, stock headers. Who told you it was a 650hp car?
