Need your help, Should I do a rear wheel conversion?
SubscribeSo as you may know my car is in the shop. It turns out that the drive shaft has to be replaced. So if I was going to do a rear wheel drive conversion this would be the time to do it. What are the pros and cons of rear wheel drive? What additional parts or things must I do to ensure good performance and safety.
Thanks for your help.
There are some older threads on this but I personally would not. Much rather prefer AWD esp if you are at a power level that is a bit higher. I feel just a very slight rear wiggle and then the car just hooks and goes straight. If it was RWD, not so much I bet!
Broken drive shaft, ya think? Hell yea, don't bother with the shaft. Take it all out. More power to the wheels.
Originally Posted by 007-911
So as you may know my car is in the shop. It turns out that the drive shaft has to be replaced. So if I was going to do a rear wheel drive conversion this would be the time to do it. What are the pros and cons of rear wheel drive? What additional parts or things must I do to ensure good performance and safety. Thanks for your help.
Quote:
More power to the wheels....Less power to the ground Originally Posted by BlackHorseTurbo
.This can be true, but I'm not having traction issues.
Quote:
I would say yes but as usual there will be some people coming out to attack ones opinion. I lay it simple and sweet...your 0-60 will fall...you will improve 1/4 mile e.t. and mph....I've been through this road before....
im going to do it just so that i can do big smokey burnouts! john force style
Read this thread.....it tells you why just in case you want to go back
https://www.6speedonline.com/forums/...k-rwd-awd.html
NO affect on traction control. PSm still works
Quote:
Vince
So how will the traction control be impacted? how hard is it to switch it back? Vince
Dude...so left that one wide open, but I'm gonna give you the benefit of the doubt as you may not have known I was on.
Yes and No.....don't really need it for 1/4 mile and 60-130....I was told for road course only
Quote:
Originally Posted by ttboost
If you go RWD, I've been told by many a reputable source that an LSD will be in your near future.
Quote:
I was told for anything making any decent kind of power (over 500whp?) DEFINITELY for road course.
