to go catless
Old Aug 14, 2009 | 05:08 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
to go catless
ok heres the deal have an 01 with a europiei loud and 100 cell cats . if i remove those boys will i see a cell ? whats the power increase? have giac, evo ics,scargo headers, evo fresh air pipeing to the turbos,evo air box,ans alwats run 100 oct. should i reflash the car for no cats??
Old Aug 14, 2009 | 05:09 PM
opps forgot kevins zero k16s
Old Aug 14, 2009 | 06:10 PM
ard's Avatar
ard
Little improvement in power, you will NOT- I repeat- NOT pass CA Smog.
Old Aug 14, 2009 | 06:15 PM
landjet's Avatar
California might cut off your b***s if they catch you.
Old Aug 14, 2009 | 06:24 PM
only have to pass smog when i sell am in a smog when you sell county, i know the hp gain was great on a corvette years ago. maybe the 100cell cat is a good thing.and not robing hp
Old Aug 14, 2009 | 06:51 PM
f1crazydriver's Avatar
f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !
Steve,
I made a thread about a year ago comparing stock exhaust vs by pass pipes with only primary cats. I think from 40-170 IIRC i gained about 2.5-3 seconds.
Old Aug 14, 2009 | 07:12 PM
ard's Avatar
ard
Originally Posted by f1crazydriver
Steve,
The backpressure with a EPII is down to 0.15 bar as compared to 0.36 for stock. A HUGE difference. Steve is already at 0.15 if he has a Europipe Loud...
Removing those europipe cats will not drop it to zero! So pick a number, is it 50%...to 0.08 bar? So this 0.07bar is about 1/3 of the initial gain from going to stock- perhaps 15 HP
(And you would cut up a $3000 exhaust to get 15 more hp?)
Stef at EP would likely have the answer...send him an email.
A
Old Aug 14, 2009 | 08:11 PM
A
Got it. I still think bypass exhaust sounds better then any of the exhaust i have heard on a turbo. And the power is there. Best of both worlds, if you are like me and can live with the noise even as a DD/DE car
Old Aug 14, 2009 | 08:12 PM
ReeknHavic's Avatar
ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !
I've decided to go catless. My concern was smell. I've been in and around several F body and Corvettes that do not have cats. The gas smell is terrible. As I understand it this isn't a concern with our cars.
Old Aug 14, 2009 | 08:17 PM
Nope its not. Then again i do have primary cats but i can still spit out flames
kwerks's Avatar
kwerks has a spectacular aura aboutkwerks has a spectacular aura aboutkwerks has a spectacular aura about
You will get a little gas/oil smell on your morning start up but it will clean up as soon as the motor warms up.
Old Aug 14, 2009 | 08:57 PM
ixotuckeroxi's Avatar
ixotuckeroxi is a splendid one to beholdixotuckeroxi is a splendid one to beholdixotuckeroxi is a splendid one to beholdixotuckeroxi is a splendid one to beholdixotuckeroxi is a splendid one to beholdixotuckeroxi is a splendid one to beholdixotuckeroxi is a splendid one to behold
so, the comp does not throw a code if you go catless?
Old Aug 14, 2009 | 08:58 PM
what about re maping and seeing a cell???is this a worth while gain over 100 cell cats?
Old Aug 14, 2009 | 11:30 PM
kwerks's Avatar
no ecu won't/should not throw a code if you go catless as long as you keep the sensors plugged into your "pipe".
exhaust flow is directly related to spool time attributes of the turbo units. Since ECU is using waste gates to control boost its naturally able to take advantage of more "free" flowing exhaust. If you remap you can add more boost, fuel, and advance ignition timing further. Having a more free flowing exhaust will help widen the added power production across the rev band. I don't know how "worth while" it is for street cars since your not competing. This mod could just be "louder" than it is beneficial. We're talking 50-300rpm difference depending on how crazy you go.
Old Aug 14, 2009 | 11:34 PM
kwerks's Avatar
I should also add you don't have to reflash for cats or any exhaust mods since your not altering fuel or ignition timing. Unless your uploading a new flash that has more aggressive mapping to take advantage of your extra flow. If your running 100 oct and no cats just do 2 megaphone tubes out the back and call it a day. You will be at 100% flow capacity from turbo exhaust side and your ignition tuning can be remapped for better flow available. But what's the point for all this in a street car?
