Checking for Boost Leaks and Poor Diverter Valves?
I am trying to see if there is a way to test for boost leaks and dodgy (faulty) Diverter Valves on my Turbo S without removing them.
I have and love the Mityvac MV8500 vacuum/pressure tester. I removed one of the supply vacuum pipes to the diverter valves and connected it up. It holds pressure up to 25psi forever but does not allow vacuum. This is probably because of a supply valve someplace.
I was wondering if there was a definitive way to test all this stuff without removing the Valves themselves to test them.
Anyone got any good ideas?
Thanks in advance.
SWR
Thanks in advance.
SWR
Thanks in advance.
SWR
Thanks in advance.
SWR
From other threads, if your DV will not hold vacuum taping into the 1/4" hose connected to the top of the DV then it is leaky/bad.
If you have a leak somewhere else, remove your intake and pressurize the whole system from just past the maf, I just sent another thread to the 1st page on how to do that.
Jul 29, 2019 11:13 AM
markski@markskituning
Aug 24, 2015 10:07 AM
ECS Tuning - VW
Aug 19, 2015 08:58 AM
