Best Place To get a 996 606 124 00 MAF?
Old Sep 24, 2009 | 05:01 PM
aggiegator's Avatar
aggiegator is infamous around these parts
Similar Ongoing Problem - '03 TT X50
I have a very similar problem. My issue shows up after about 20min of driving (after resetting codes and cleaning MAF) with uneven idle speed, or a constant idle of 1200 to 1500 rpm with the cluth disengaged, and hard on PMS and ABS lights. If I let it go, my check engine light also will come on. The code I get is the same as yours except when I let it progress long enough to get the check engine light, then it indicates a high idle issue plus the MAF code.
I have suspected that my MAF may have went bad. Short story: took car into body shop for paint work on front air dam, pick car up after many bad rainstorms, car has factory aero w/ EVO intake, go to start car, shop has to jump start it???, car runs very rough and wants to stall, keep it running but seems to act like it was injesting rain water, my theory is that it either shorted something out or the MAF went bad from the water passing through it???
Your post may be a big help to me because I have asked several mechanics to no avail. I will give it a shot unless someone has something else to add.
Thanks,
Brian
Old Sep 24, 2009 | 05:43 PM
ShokWaveRider's Avatar
ShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to all
Thanks,
Brian
Brian:
Before you start forking out cash please take a look at your Durametric readings.
tropicatango
Jun 8, 2025 01:00 PM
Oct 6, 2015 05:20 AM
BLKonBLK911C4S
NorCal
Aug 29, 2015 03:20 AM
Aug 19, 2015 06:55 PM
