Porsche Ceramic Brakes
Old Nov 16, 2004 | 05:52 PM
wings2's Avatar
wings2 is infamous around these parts
Just took delivery of a 2005 TT Cab and when hot (in town stop and go traffic) the brakes make a sound like a dump truck in heat. The sound is loud enough to turn heads at the bus stop. Porsche tells me that this is "normal" for these brakes. Anybody got some experience with this?
Old Nov 16, 2004 | 06:08 PM
rmrmd1956's Avatar
rmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of light
Is it sort of like a metal grating noise that sounds very unnatural?
Old Nov 16, 2004 | 06:16 PM
FAT-911's Avatar
FAT-911 is infamous around these parts
Sometimes the brakes make noise when they get dusty, let the brakes cool down then hose them especially in the holes, drive it around and if the sound persists take it back to the dealer.
Old Nov 16, 2004 | 06:23 PM
Moogle's Avatar
Moogle is infamous around these parts
normal
Old Nov 16, 2004 | 06:58 PM
ben, lj's Avatar
Senior Member
ben, lj has a spectacular aura aboutben, lj has a spectacular aura about
Originally posted by Moogle
normal
that is weird. i hear all this and porsche's "normal" response and i just can't understand why after POUNDING the ceramic brakes (clean/dirty, wet/dry, etc) on my stradale for the whole 1k+ miles i've had it, they've never made a peep.
Old Nov 16, 2004 | 07:47 PM
20C4S's Avatar
the PCCB on my GT3 is very quiet so far & that is NOT normal.
that'll give u an idea...
Old Nov 16, 2004 | 07:51 PM
20C4S's Avatar
ben,
i think the difference in the PADS.
Old Nov 16, 2004 | 07:57 PM
Jack(LA)'s Avatar
Moderator
Jack(LA) is infamous around these parts
I agree with Arling -- it's not normal. My GT2 never made any "bad" braking noises. A friend did have a strange noise coming from the rear of his GT2 under braking (a deep groaning sound), and it turned out to be a bad PCCB rear rotor (inside rotor surface was cracked -- car needed to be inspected on the lift to see the rotor damage). It was replaced under warranty.
Old Nov 16, 2004 | 07:58 PM
ben, lj's Avatar
Senior Member
Originally posted by 20C4S
ben,
Any reason Porsche doesn't use these pads? I thought it was insufficient cooling with 996s and the ceramics which is supposedly addressed with 997 engineering.
Old Nov 16, 2004 | 08:16 PM
collin996tt's Avatar
Senior Member
collin996tt is infamous around these parts
rejexing your rotors is not normal
Periokid's Avatar
Periokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud of
Mine are quiet.
Old Nov 16, 2004 | 08:23 PM
Moogle's Avatar
its all about the pads, there are 3 versions i believe
comfort/sport/track
try comfort
Old Nov 16, 2004 | 08:25 PM
Senior Member
comfort/sport/track
u mean quiet/squeaky/cranky
Old Nov 16, 2004 | 08:34 PM
Moogle's Avatar
hahaha collin.
if it was up to me, i would stick with steel, as i did on my GT3
on the TT-S they are standard... nothin you can do
im currently researching if the second generation PCCBs (which are reportedly a huge improvement), as fitted to the 997s, are retrofittable to the 996's
Old Nov 16, 2004 | 08:52 PM
20C4S's Avatar
comfort/sport/track
try comfort
very confusing indeed. surposely the comfort one is P90-2. sport one is P40-1. track one is P91. i'm pretty sure the number except the track use one. anyway, recent test done by us the sport doesn't make the ''normal'' noise like the comfort pad... isn't it confusing??
