GIAC Flashloading officially available!
Old Nov 17, 2004 | 07:03 PM
PorschePhd's Avatar
As of this evening guys I can officially release that flash loading for the TTs is now available. This means that no longer must you desolder anything from the ECUs. We simply place a plug in the OBD II port, read down the proper information for your vehicle and reload the performance software in its place. No errors, no soldering, no cracking over the cover. All the software you have received through the older soldered version is available in a flashload. If you send the ECU through the mail the ECU will be flashed and checked on the bench. As usual GIAC writes all the software in a factory manner so that everything is left in tact, all adaptive functions and safety margins are in place.
If the dealer flashes over your program the GIAC dealer that flashed your ECU will have that stock file and can simply reflash the ECU back to your performance file. No hassles with dealers.
Old Nov 17, 2004 | 07:05 PM
MKW's Avatar
MKW
MKW is infamous around these parts
Can it also flash over other tuner brand programs already placed there the old desolder/solder back way ?
Old Nov 17, 2004 | 07:20 PM
Pierre996TT's Avatar
Pierre996TT has a spectacular aura aboutPierre996TT has a spectacular aura aboutPierre996TT has a spectacular aura about
Can I get upgraded this way when I will send you my ECU (going Stage III ---> Stage IV)?
or my ECU is already solder with a chip, and can not be turn?
I think is a more clean set up.
Old Nov 17, 2004 | 07:30 PM
PorschePhd's Avatar
Pierre,
It can be swapped. Even with the soldered version we keep the stock files on all of our customers for future need.
MKW there is also a solution for you as well. Not a problem.
Old Nov 17, 2004 | 08:17 PM
luting_chen's Avatar
luting_chen is infamous around these parts
Stephen:
can this work with the IBE? or is the ibe still being worked on?
Old Nov 17, 2004 | 08:19 PM
SteveH's Avatar
SteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud of
so that's it then stephen, you're basically retired now
Old Nov 17, 2004 | 08:20 PM
PorschePhd's Avatar
There is going to be an option for the end user to change programs. It however is not released yet. Very soon.
JC996TT's Avatar
JC996TT is infamous around these parts
You won't need the IBE soon enough
Old Nov 17, 2004 | 08:23 PM
PorschePhd's Avatar
LOL, retire. Now that is funny. That would be the day when a computer can install rods for me
Old Nov 17, 2004 | 09:37 PM
SHANKENFELTER's Avatar
SHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud of
That is fantastic! Way to go.
Old Nov 17, 2004 | 10:05 PM
MKW's Avatar
MKW
Does the solution require pulling the ECU box or can the OBD II port be used only . That's the gist of my original question . TIA.
Old Nov 18, 2004 | 09:11 AM
PorschePhd's Avatar
If you have a local GIAC dealer near you and as long as the program you have now is not hard encrypted then the ECU will not have to be removed. It can simply be reflashed. If you have a GIAC program now the ECU will have to be removed to update to the flash software.
Old Nov 18, 2004 | 09:20 AM
MKW's Avatar
MKW
My current program ( not GIAC) can be overwritten / reflashed by the dealer if there were a mandatory factory ECU update .I chose that option . Is that the same as " not hard encrypted " ?
Old Nov 18, 2004 | 09:29 AM
Fabryce@GMGRacing's Avatar
Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !
For all you Southern California guys
We are offering the GIAC software also.... And if you need any other tuning or race prep related modifications please feel free to call me at the shop.
GMG
Global Motorsports Group Inc
71 4-432-1582
Old Nov 18, 2004 | 09:44 AM
WARDHOG's Avatar
WARDHOG is infamous around these parts
Is anything in works from you guys for N/A engines? I've heard you can't much more out of them.
