brake upgrade question
Old Sep 23, 2009 | 09:16 AM
Mad Ness's Avatar
Mad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant future
Street car, no sustained hard braking as on track, but will be required for hard street/gradient mountain runs and to fill up 19s for looks. Priority is performance over looks.
p.s. i searched around but inconclusive. thanks!
Front:
Will a brembo monoblock 6pot 15" rotor brake kit from a 997 C4 bolt onto a 996tt? Found this site and the part is listed together for both cars, just want to get confirmation: http://www.automotion.com/product.as...9&dept_id=4209
- If not, is the rotor-hub or the caliper spacer the issue?
- are the brake hoses the same?
Rear:
Given the above set up for front, comments on feasibility of the following:
- stock 996tt rear caliper and a larger 2pc rotor. please comment on rotor size for best match.
- stock 996tt front caliper and larger 2pc rotor. please comment on rotor size for best match.
Old Sep 23, 2009 | 09:24 AM
996Choy's Avatar
996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of996Choy has much to be proud of
I'd suggest GT3 6pot + 997 TT rotors for front. I have that setup + pagid yellow pads and it's great for street / track duty.
(there used to be a brake thread around on sticky, dunno where it has gone)
Old Sep 23, 2009 | 09:45 AM
Mad Ness's Avatar
yea i read that post. gt3s and gt2's have different hubs to the awd platforms. From what i can find online, the 996tt/997tt/997C4S brake parts are interchangeable ... reason for asking is cos i've located a deal on a second hand set from a 997c4s.
the gt3 and 6pot monoblock is the same caliper is it not?
Old Sep 23, 2009 | 11:10 PM
Mad Ness's Avatar
right, thanks. thing is Im looking at a kit that came off a 997 c4s so another way to ask the question then is whether the 997tt and 997c4s brake parts are interchangeable?
Old Sep 24, 2009 | 07:04 AM
landjet's Avatar
Call Suncoast Porsche and ask for Aaron. He'll either tell you or find out the correct info. Suncoast sells a lot of brake upgrades.
Old Sep 25, 2009 | 12:04 PM
hanst's Avatar
hanst is infamous around these parts
I think that modified GT3 6pots and cup rotors are the best and less expensive way to go.
Old Sep 25, 2009 | 01:55 PM
pete95zhn's Avatar
pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !
997 turbo rotors and 6 piston calipers should be a bolt-on job. I installed those on my '00 C2 with GT2 wheel carriers, and had to use 1,5mm shims between disc and hub. --> with turbo carriers no problems ( = no shims ).
Old Sep 25, 2009 | 02:47 PM
landjet's Avatar
I upgraded to the 996 GT3 6 piston fronts with 997TT rotors. Was a direct bolt up.
Jul 29, 2019 11:13 AM
The Oss
Aug 24, 2015 08:19 PM
Vrseis
Aug 20, 2015 07:41 AM
ECS Tuning - VW
Aug 19, 2015 11:08 AM
