which tyre for 19's
Old Sep 27, 2009 | 02:28 PM
Neil A's Avatar
Neil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud of
which tyre for 19's
Hi looking for some advice on tyre choice, im running 235/35/19 front and 305/30/19 rear Pilots just now but will be needing to change them soon.
I have got prices for the same size front but 315 /25/19 rears so what would you guys recommend .
I got quotes for Toyo Tr1's, Falken FK452 and Michelin Pilots ,with the Pilots being nearly twice the price of the other two.
Old Sep 27, 2009 | 04:52 PM
infinus's Avatar
infinus is infamous around these parts
Ive used the falkens on my G35 and I like them. I like the vredestein's better but they don't make them in the right size for the rear.
Old Sep 28, 2009 | 06:54 AM
Neil A's Avatar
Thanks for the reply i havent ran falkens before, i have used the Toyo's but only on a light fwd car not sure what they would be like on a 996 as the sidewalls are fairly soft.
Old Sep 28, 2009 | 09:28 AM
Mad Ness's Avatar
Mad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant future
yokohama ad08 know it comes in 235, 295 and i think 315
Old Sep 28, 2009 | 09:31 PM
Yves's Avatar
Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !
I'm running the Toyos on my car. Same front as what you currently have.
315/25/19 in the rear.
Couldn't be happier and I ranPS2 before. My car is a DD.
Save my track stupidies for the Ducati
Old Sep 29, 2009 | 12:21 AM
Danyol's Avatar
Danyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant future
Running the T1R (315/25-19) for over 6 months on DD; rain or dry an excellent tire.
Old Sep 29, 2009 | 06:36 PM
Neil A's Avatar
Thanks alot guys what sort of pressures are you running front and rear cold?
Any problems with high speedstability or sidewall flex?
The other tyre i was looking at that i can get in the sizes i want is the Yoko Advan Sport V103.
Old Sep 29, 2009 | 07:14 PM
Danyol's Avatar
34 F, 40 R; i've seen no instability all the way up to 120 (my suspension mods likely affect this too). Sidewall flex? 25 series tire what sidewall! how can one sense this?
Old Sep 29, 2009 | 11:12 PM
Turbo Fanatic's Avatar
The 305/30-19 in rear is 4% larger around than the proper size 315/25-19. Assuming you are running that setup on a 996 TT, It is possible to overheat and damage the viscous coupling by overheating it.
Old Sep 30, 2009 | 11:24 PM
Neil A's Avatar
Thanks Ari i had heard this before and its one of the main reasons i want to change tires, i have only recently got the car and it hasnt had the 19's on it for long so hoping no damage has been done.
Old Oct 1, 2009 | 09:49 AM
Danyol's Avatar
I had the same thing when I bought my car; all seems to be well though, not sure how you could tell the coupling is damaged. Guys at the dealership didn't see the 305's as unusual, I went to the 315/25-19 a few months later.
I did notice some weeping around the front diff case drive shaft seals when I changed my oil. Not sure if it's related.
manfred@loma_wheels
Sep 2, 2015 11:22 AM
MrBlonde
Mar 7, 2007 02:10 AM
Parker
Ferrari
Sep 29, 2004 02:49 AM
