cross rotating rear tires?
Old Oct 1, 2009 | 07:17 AM
x50surfer's Avatar
x50surfer is infamous around these parts
Hi All - I was thinking about trying to extend rear tire life by cross rotating them. Does anyone have experience with this? I'm running ps2's. thanks, Jim
Old Oct 1, 2009 | 07:45 AM
PAULIEWALNUTS's Avatar
PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !
I believe they are directional.
Old Oct 1, 2009 | 08:45 AM
WOODTSTER's Avatar
That is correct Parasole, but as long as you keep them mounted on the
wheel, then when you put in on the other side of the car it is turning
in the correct direction.
We do this alot at Brainerd (Horrifically dangerous track) to keep our
driver side tires from being obliterated while our passenger side tires get
the big easy.
MK
Old Oct 1, 2009 | 08:52 AM
Danyol's Avatar
Danyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant future
Besides giving Paulie a hard time I'm trying to see the logic. The tire would need to be removed from the rim and flipped to keep a directional tire rolling in the correct direction on the opposite side of the car. Sorry if I'm being slow
the big easy.
MK
Old Oct 1, 2009 | 09:12 AM
landjet's Avatar
On the side of the tire you will see the word "outside" written in the rubber. As long as this side is always to the outside you can run them on either side of the car.
Old Oct 1, 2009 | 10:00 AM
Danyol's Avatar
My tires have an arrow and indicate which side of the car they should be.
Old Oct 1, 2009 | 10:07 AM
MotorsportsR's Avatar
MotorsportsR is a splendid one to beholdMotorsportsR is a splendid one to beholdMotorsportsR is a splendid one to beholdMotorsportsR is a splendid one to beholdMotorsportsR is a splendid one to beholdMotorsportsR is a splendid one to beholdMotorsportsR is a splendid one to behold
I don't think PS2 are directional. I think it is only outside and inside.
Old Oct 1, 2009 | 10:44 AM
RiA's Avatar
RiA
RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !
I do it with the T1Rs - it almost doubles the life of the rears.
It's not possible with the MPS2s and keep them running as specified by Michellin.
Old Oct 1, 2009 | 10:14 PM
Danyol's Avatar
The tires I have pictured are T1Rs; how do you rotate them (tires off the rims?) and at what interval?
Old Oct 2, 2009 | 12:23 AM
RiA's Avatar
RiA
Dismount both, move to opposite sides, keep rotation same direction, remount and rebalance - done.
Measure thread depth and swap at the half-way point (don't hit the wear bars before you swap).
Old Oct 2, 2009 | 02:12 AM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
wow what a pic in your avatar any story on that crash?
Old Oct 2, 2009 | 03:00 AM
Cross rotated my tires!
Old Oct 2, 2009 | 05:53 AM
Danyol's Avatar
Looks like they were cross rotated at speed
Old Oct 2, 2009 | 07:26 AM
damon@tirerack's Avatar
Moderator
DING DING DING, we have a winner! I was waiting to see who would catch this first. PS2's are asymetric, not directional. Once properly mounted they can be flipped from side to side. Unless you remove a tire from the rim and move it to the other side of the car and remount, flipping an asymetric tire probably won't result in better wear. Given that many of today's tires, PS2 included, have different rubber compounds as you move across the treadcap it really isn't a good idea to flip an asymetric tire on the same rim and try to run backwards. Bad wear characteristics could result.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
oufan2929
Nov 8, 2015 08:26 PM
L.A.P.
Oct 19, 2015 10:01 PM
horsepowerfarm
Sep 10, 2015 06:09 PM
L.A.P.
Aug 23, 2015 11:48 PM
Sterlingc1975
Aug 22, 2015 02:30 PM
