Preparing the 996 for the mile.. New fuel system, dyno..
Old Oct 11, 2009 | 09:58 PM
  #31
Chris Green's Avatar
Chris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond reputeChris Green has a reputation beyond repute
Originally Posted by VividRacingTX
You have proven to the naysayers that you don't need 850whp in a 996TT to hit 200 and 717whp does the trick. Awesome Chris, good job. Do you know how much your car weighs? Was there a tail or head wind? Temp?
The air was pretty much still no head or tail, about 95 out and nasty humidity, last time I weighted the car pretty sure it was like 3300.
Old Oct 11, 2009 | 10:06 PM
  #32
ReeknHavic's Avatar
ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !
Congrats Chris that's a super impressive speed for the 18g in the mile.
Old Oct 11, 2009 | 10:18 PM
  #33
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
Don't forget guys that e85 runs really cold maybe Chris can chime in and came in handy I am sure in these conditions. It reduces the IAT big time and plays a great factor in this run. With taller tire Chris I think it would have been better also. Great run.
Old Oct 11, 2009 | 10:52 PM
  #34
Jean's Avatar
Jean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond repute
Congratulations Chris, those are excellent numbers!
Old Oct 11, 2009 | 11:17 PM
  #35
flash68's Avatar
flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !
Chris, congrats. An impressive number for sure!
Old Oct 12, 2009 | 07:01 AM
  #36
onelove's Avatar
onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !
Congrats Chris, was fun out there today even though it was hot as all hell. With your car doing this in this heat, I can't wait to see what it will do in January. Definitely plan on having our ****box ready to run out there as well as it looked like a blast.
Old Oct 12, 2009 | 07:04 AM
  #37
ttboost's Avatar
Congrats Chris!!! What size tires were you running and what do you think for next time? What was your limiter set at?
Old Oct 12, 2009 | 02:33 PM
  #38
315-25-19, next time I will use a 305-35-19. rev limter is set @7500
Old Oct 12, 2009 | 02:37 PM
  #39
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
Ah, so it's your tire size. I should be good with stock tire sizes then. I ran 19's last year but ran with stock 18's in March.
Old Oct 12, 2009 | 03:39 PM
  #40
ttboost's Avatar
Old Oct 12, 2009 | 05:27 PM
  #41
LamboTT's Avatar
LamboTT has a spectacular aura aboutLamboTT has a spectacular aura about
You can probably grab a cheap drag radial in that size too.
Old Oct 13, 2009 | 07:14 AM
  #42
Jean's Avatar
Chris,
I understand your car is a Tip, shouldn't you get to 220mph without problems with this tire size and RPM limiter..
Old Oct 13, 2009 | 11:15 AM
  #43
Powell's Avatar
Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !
Jean his car is still a 6speed. VividRacingTX is our local tippy.
Something still doesn't add up. We've done all the calculators including the one that predicted SW's speed vs RPM and it was .2mph off of it. It is saying a 315/25/19 is good for 217mph.
Old Oct 13, 2009 | 11:24 AM
  #44
onelove's Avatar
I believe Chris was running Nitto Invo tires, which at a 315/25/19 size have a diameter of 25.28 which may make up for the slight variance depending on how you determined the outer diameter.
Old Oct 13, 2009 | 12:56 PM
  #45
Jean's Avatar
Thanks Powell, my mistake, I read the wrong signature.
Add to the theoretical calculations of the 6speed box another 2-3% of tire expansion at those speeds. The 25.28 diameter is quite consistent with the calculations, top speed at 7500RPMs is around 220mph.. At 7000 RPMs it is closer to 205mph.
