997 Turbo? (questions)
Old Nov 24, 2004 | 03:13 PM
Chordate's Avatar
Chordate is infamous around these parts
I was just wondering, what Turbos will the 997 Turbo use (K16 or K24?) and will it be a 3.8 or 3.6 l engine?
Old Nov 24, 2004 | 03:23 PM
Chordate's Avatar
Could someone post that autoweek article on the turbo? Maybe that had that info?
Old Nov 24, 2004 | 03:37 PM
JASCLASS's Avatar
JASCLASS is infamous around these partsJASCLASS is infamous around these parts
Sounds like it will be a 3.8
Old Nov 24, 2004 | 03:39 PM
fdb996c2's Avatar
fdb996c2 is infamous around these partsfdb996c2 is infamous around these parts
Old Nov 24, 2004 | 03:40 PM
Chordate's Avatar
Thanks... so the 997 GT3 will also be a 3.8 probobly?
Old Nov 24, 2004 | 03:51 PM
james's Avatar
Carolina Speed
james is infamous around these parts
Here's a best guess from all of the recent articles: 3.8L with 490+ hp, 19" wheel with a new twist on the turbo twist, keeping the AWD, DSG (direct shift gearbox), PASM active suspension management, PSM stability management (possibly a track setting that allows greater slip with less aggressive throttle cut and remove the ocsnl miscut with heel toeing), PCCB II option, a seat that is slightly more comfortable than the GT-3 seat that still folds, upgraded Bose stereo, lighter hood and trunk (aluminum vs CF), larger front intakes with larger ducts and ducting to the front brakes and scoop for rear rotors, and release in mid 2005.
Old Nov 24, 2004 | 03:55 PM
james's Avatar
Carolina Speed
400 bhp 3.8L based off the Carrera S, central rear exhaust, bigger rear wing, extensive CF in the body, lower front lip, PCCB II, and a club sport package with roll cage, harnesses, and extinguisher.
Old Nov 24, 2004 | 05:00 PM
RDH's Avatar
RDH
RDH Is a GOD !RDH Is a GOD !RDH Is a GOD !RDH Is a GOD !RDH Is a GOD !RDH Is a GOD !RDH Is a GOD !RDH Is a GOD !RDH Is a GOD !RDH Is a GOD !RDH Is a GOD !
Porsche Excellence had it as a 3.8 with K24s as the stock platform along with an agressive new transmission...
Old Nov 24, 2004 | 05:29 PM
PorschePhd's Avatar
I have from close sources that the engine will be similar, however the turbos will be a Variable vein. We will have to wait and see. it is possiable it will be a 3.8 yet I hear that the 3.6 will be fitted. Hard to tell what is truth and what is not.
Old Nov 24, 2004 | 05:30 PM
GFORCED's Avatar
Built to Blast
GFORCED has much to be proud ofGFORCED has much to be proud ofGFORCED has much to be proud ofGFORCED has much to be proud ofGFORCED has much to be proud ofGFORCED has much to be proud ofGFORCED has much to be proud ofGFORCED has much to be proud of
Newport Auto Center has deposits for 40 997 turbos.
Get in line...
Old Nov 24, 2004 | 05:37 PM
TT Surgeon's Avatar
3.6 for the turbo, 3.8 for the gt3.
????c4s997 3.8 engine!!!!
Old Nov 25, 2004 | 08:10 AM
msindi's Avatar
Autocar said 3.6 with 460bhp so I guess K24s (building on current X50)
Old Nov 25, 2004 | 08:17 AM
rockitman's Avatar
rockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond repute
Hey this is a 996 board. Please refer all bastardized 997 questions over to the appropriate forum. Thank you...
COBB Tuning
Jan 1, 2025 09:02 AM
Aug 21, 2015 06:34 AM
PelicanParts.com
997 Turbo Vendor Classifieds
Aug 20, 2015 02:38 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
PelicanParts.com
Aug 18, 2015 03:41 PM
