New guy with bigish problem
Old Oct 14, 2009 | 04:10 PM
Mpsuk's Avatar
Mpsuk is infamous around these parts
Hi, im new to this forum, and new to porsches. Around three months ago i brought a silver 2001 996 turbo x50. I absolutly love the car but little did i know when i got it it was in safety boost ( 0.4 bar ). I was told to swap maf semsor, made no difference, so i took it to a specialist. He said their was a leak on the manifold and so it was fixed. When i drove the car it rarely produced 0.7 bar and when acceleratong hard it would boost usualy 0.7 or 0.6 and then after around 4500rpm boost start tailing off to 0.4 or 0.5 to redline. I was told this was normal??? I have now put on an agency power filter which is great and had an ruf race map on the car set to run 1.3 bar. Now the car will pull 1.0 bar and tail off as before but to 0.8 or 0.9. So same problem of not making enough boost and boost tailing off but just more of. My brother is a mecjanic but isnt to familiar with porsches, he thinks a sensor may be sending wrong signals to the ecu??? Any suggestion or idras would be very much appreciated. Thankyou in advance
Old Oct 14, 2009 | 04:26 PM
buzzm's Avatar
buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !
i have no idea what your poblem is but if i was in your position i would find a good porsche tuner and have them run a diagnostic, i know england is a tiny little island but they must have a few good p'car tuners
good luck to a fellow brit
Old Oct 14, 2009 | 04:30 PM
Bodybag's Avatar
Bodybag has a spectacular aura aboutBodybag has a spectacular aura about
DV Valves are leaking?
Old Oct 14, 2009 | 04:37 PM
MBailey's Avatar
Hook it up to Porsche diagnostic machine at dealer or you can get your own Durametric program. Check for codes. If none, built a boost leak tester like the one Colorinc built (do search here for boost leak tester). Test for leaks at pressure you should be at. Fix any leaks. Most of the time these two steps will resolve low boost problem. If not try replacing spark plugs. If that does not work ask someone smarter than me.
Old Oct 14, 2009 | 06:36 PM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
bleeding off of boost is generally due to leaks, hoses DV"S(Blow off valves) gaskets or possibly faulty waste gates
boost doesn't trail off unless your turbos are running completely maxed n dieing off which at .8bar stock they are not
pressure test the system from the turbos to see if it holds
Old Oct 14, 2009 | 07:19 PM
Mpsuk's Avatar
Smile
Hi, thankyou for replies. One thing i forgot to mention is that one specialist pulled off ( what i believe to be ) the pipe going to the actuators just to test the car. After this the car drove extremely well and held full boost to the rev limiter. If the problem was from a boost leak or faulty dvs would the boost have increased any when mapped? Again thankyou in advance for very useful advice
Old Oct 14, 2009 | 07:21 PM
Mpsuk's Avatar
Sorry, also the car has been on porsche diagnostics twice and came up fault code free!!!
Old Oct 14, 2009 | 07:23 PM
the F hose is what that hose is called and it sounds like you either have a leak
would the boost increase when you flashed the car to try n build more boost maybe but it wouldn't hold.
Old Oct 14, 2009 | 07:35 PM
Mpsuk's Avatar
Ive got the car booked in for oil and filter service and pit better plugs to cope with increased boost. I think the pipe the guy pulled off was underneath near the turbo
Old Oct 15, 2009 | 01:08 AM
alex55's Avatar
alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !
ok, if the car is x50 you should have 0.9-1.0bar not 0.6-.07 and you need dvs asap
Old Oct 15, 2009 | 02:26 AM
ScottKelly911's Avatar
ScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond repute
As for tuners in England, I'm pretty sure that Manthey in Surrey if I remember correctly is a well respected tuner. I've never been to England, so I have no clue as to proximity to you. But you're getting a lot of good advice, it really does sound like a boost leak somewhere.
Old Oct 15, 2009 | 05:22 AM
Mpsuk's Avatar
Ok guys, thanks for all the advice, ill get new dump valves fitted as soon as i can then repost on progress if any.
Old Oct 15, 2009 | 05:36 AM
ShokWaveRider's Avatar
ShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to all
I would do the boost leak test first, it is easy and cheap to do. However, your problem does point to the DVs though. Perhaps the "F" Hose but those plastic DVs typically only have a 5 year life. The diaphrams could be ripped.
If you are a little mechanical and a hobbyist, doing the boost test is quite a fun project. I personally built a couple of test parts very cheaply. If you search on Boost or Pressure Test you should find it.
Pulling the actuator hoses off could be dangerous. Although they will start to chatter at about 1 bar. I would replace them with 1 bar units personally and adjust them to 13psi.
Good Luck.
Old Oct 15, 2009 | 06:31 AM
UrbanHotrod's Avatar
UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !
+1 on the boost leak test, as well the DV may just be leaking, What fuel are you running to hope to hit 1.3 bar?? that's a little scary if you ask me.
Old Oct 15, 2009 | 08:05 AM
Mpsuk's Avatar
Hi, im probably not the most knowledgable mechanic in the world but if i do attempt a repair i try to do everything to the highest possible srandard, i do realy enjoy working on the car so will try out this boost presure test. I feel i will need to swap dump valves anyway so will do that asap. I use the super unleaded fuel from the shell petrol stations in uk, 99 octane
