Turbo S K24's
Old Nov 4, 2009 | 07:41 AM
ikold's Avatar
ikold is infamous around these parts
Turbo S K24's
I'm about to pull the trigger on a Turbo S cab. It will be my first TT. Had a Carrera prior.
How expensive and time consuming should it be to upgrade to the K24 Hybrid turbos. I'm in Santa Fe NM anyone have a good shop in NM or AZ or CO they would recommend.
Is there anything special I should do to maintain the ceramic brakes
Car will need new rubber soon. Any suggestions on a reasonable wearing and priced tire (stock rims).
Anything must mod items I should as soon as I get the car?
Old Nov 4, 2009 | 07:50 AM
iJeremy's Avatar
iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !
Which hybrids are you considering? - Your cost will be slightly lower since you'll already have the K24 side... Find a tuner that does a Core-Exchange. You mention Arizona, surely you've stumbled across Evo and Vivid by now if you're in the Porsche world...
If it were me I'd stick with your stock K24's for now and spend the money on a good exhaust/tune/intake/DV's and PSS10 suspension. You should be able to do all that under 8k and it will completely transform the car. For tires there's a number of good sets just depending on what your budget allows for. Everything from the Sumi's up to the PS2's have been discussed in great length on the forum, do a quick search and you'll find hours of useful reading.
Congrats on your new 996tt and be sure to post up pictures asap!
Old Nov 4, 2009 | 08:24 AM
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
Go with K24/18G hybrids and proto tune and injectors. These cars are bullet proof. BBi in Huntington Beach could help you with these.
Old Nov 4, 2009 | 08:36 AM
ikold's Avatar
Probably a dumb question but in the S does the car have dual 24k's or a 24/18 setup?
Where is Vivid? Have been to EVo.
Old Nov 4, 2009 | 08:46 AM
Tony@epl's Avatar
Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !
HI,
I'd highly recommend trying to find a shop in Santa Fe or at a similar altitude (~7000ft). You want your car to be built and tested by a tuner in the same conditions it will be run daily.
We have shop we work with in CO that is at ~6000-6500 feet which should be able what your altitude is.
It might be alittle bit of a drive to CO (Denver area), but it will be worth it to have your car remote custom tuned for altitude.
Old Nov 4, 2009 | 08:50 AM
ikold's Avatar
yes
I definitely agree. What is the name of the shop? I want a tune specific to the altitude I live at.
What upgrade do you suggest I do first. Hybrid turbo's / ECU / Intake.
Old Nov 4, 2009 | 08:54 AM
Tony@epl's Avatar
http://www.autosportwerks.com/ - I make it out to Denver 2-3 times a year to custom tune as well. I will be out there 1 more time before the new year if you would like me to tune the car in person.
Since the car is already equipped with k24s... I'd recommend k24/18g's, injectors, an exhaust and all the necessary maintenance (if any).
Drop me an email if you would like to discuss further.
COBB Tuning
Jan 1, 2025 09:02 AM
Jul 29, 2019 11:13 AM
BlackMarketRacing
Dec 8, 2015 01:49 PM
BlackMarketRacing
Dec 3, 2015 10:46 AM
Christian
Aug 24, 2015 12:56 PM
