5th MAF is blown...
Old Nov 21, 2009 | 07:00 PM
  #31
aroonkl's Avatar
aroonkl is a jewel in the rougharoonkl is a jewel in the rougharoonkl is a jewel in the rougharoonkl is a jewel in the rough
Ordered on Thurs. Overnighted, came to me on Fri eve. Great service.
Old Nov 23, 2009 | 07:12 AM
  #32
GreggT's Avatar
GreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to behold
Excuse my ignorance......am I correct to assume your car has already been tuned for the Hitachi?
Old Nov 23, 2009 | 08:04 AM
  #33
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
considering he ordered the hitachi MAF from his tuner im sure he got a flash to go with it.
Old Oct 29, 2012 | 08:10 AM
  #34
gclasse's Avatar
gclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond repute
My Bosch MAF failed last week and it seems to be a better idea to do the upgrade.. Does anyone know the part number of the HITACHI MAF??
Current Mods:
EVOMS V-Flow Air Box
GIAC
Fab Exhaust
Old Oct 29, 2012 | 08:24 AM
  #35
wross996TT's Avatar
Current Mods:
GIAC
Fab Exhaust
Lose the V-blow...I lost several MAFs with this box...I've lost none since I replaced it. You can't just change the MAF without changing the ECU tune.
Old Oct 29, 2012 | 08:29 AM
  #36
johnspeed's Avatar
Thumbs up
..agreed...A saw a couple of my fellow PCA members go thru the same thing.
Old Oct 29, 2012 | 12:14 PM
  #37
gclasse's Avatar
Definetively will require a reflash of the giac software for the hitachi... But what about the MAF part number??
Old Oct 29, 2012 | 03:39 PM
  #38
VGLNTE1's Avatar
VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !
how did you know it was done for? just throw a code? I am getting the MAF check engine light code, plus throwing PSM and ABS at full boost. Where and which one of the Ford Mafs to get? and is this Ford as in....Ford motor company? ugh
also, will the car need a new flash?
Old Oct 29, 2012 | 04:00 PM
  #39
gclasse's Avatar
HITACHI MAF Part No.??? anyone??
Old Oct 29, 2012 | 04:21 PM
  #40
Tim941NYC's Avatar
Car wont run right on the hitachi.. you also need a jumper harness and a re tune. who ever is retuning the car can give you the part# to use. You also will need the tube that the maf bolts up to.
Old Oct 29, 2012 | 04:29 PM
  #41
gclasse's Avatar
Tim, Agree... but how come that the car wont run right???
Old Oct 29, 2012 | 06:31 PM
  #42
Ford maf are not direct replacements and require a custom bench flown tuning tube along with a housing. Not to mention the Ypipe has to be a certain shape to prevent wrong maf readings...
it sounds like you have some boost leaks as well... maybe maf... you need a good set of eyes on the car....
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Oct 30, 2012 | 05:39 PM
  #43
Hector-PRAC's Avatar
Hector-PRAC has a brilliant futureHector-PRAC has a brilliant futureHector-PRAC has a brilliant futureHector-PRAC has a brilliant futureHector-PRAC has a brilliant futureHector-PRAC has a brilliant futureHector-PRAC has a brilliant futureHector-PRAC has a brilliant futureHector-PRAC has a brilliant futureHector-PRAC has a brilliant futureHector-PRAC has a brilliant future
+1
I had a maf blown a few weeks ago which was the result of a boost leak. The leak was discovered from one of the small hose that goes to the plenium. Boost leak was solved and maf was replaced with an OEM. running good so far @ 1.5bar
BLKMGK
May 31, 2016 04:32 AM
WheelsupZR1
Oct 20, 2015 08:36 PM
panas001
Sep 27, 2015 02:51 PM
troyztoyz609
Sep 17, 2015 06:09 AM
