I think I toasted my clutch..
Old Nov 22, 2009 | 04:09 PM
GoingFast's Avatar
GoingFast is infamous around these parts
I was cruising on the highway, pressed the gas pedal in 5th gear, the RPM went to 7K, but the speed stay the same. After cruising for 5 minutes on the highway, the car just died on me without any CEL. When it was towed to the shop, I can smell the stench of the clutch. I hope it is only a clutch issue. I was able to start the car and drive it, but only did it for a few feet since I don't want to damage anything else.
How do you know when time to change your clutch? I didn't notice any different in the feel of the clutch when I change gear. I heard OEM clutch is about $800. How many hour does it take to do this job. While I am doing my clutch, what else should I need to do so I can take advantage of saving on the labor cost. The car is an 01 with 51K miles on it and it has all OEM parts. The car was in the shop last week to have the left radiator replaced.
Thanks for any advices and thank you for reading,
TC and Happy Turkey Day!
Old Nov 22, 2009 | 04:12 PM
gt2rs6's Avatar
gt2rs6 has a spectacular aura aboutgt2rs6 has a spectacular aura about
sounds like the clutch is finished just put a better than stock one in that way you dont have to change it again if you start making big power
Old Nov 22, 2009 | 04:21 PM
MBailey's Avatar
Does sound like clutch is done. I would put a slightly upgraded Sachs back on so you never have to change again. The cost of the clutch is not as big a deal as the labor (Stealer = 17 hours @ roughly $120/hr) unless you get a high hp much higher cost clutch.
Old Nov 22, 2009 | 05:11 PM
BlueFVD-575's Avatar
BlueFVD-575 is a splendid one to beholdBlueFVD-575 is a splendid one to beholdBlueFVD-575 is a splendid one to beholdBlueFVD-575 is a splendid one to beholdBlueFVD-575 is a splendid one to beholdBlueFVD-575 is a splendid one to beholdBlueFVD-575 is a splendid one to beholdBlueFVD-575 is a splendid one to behold
Just did mine.....1700 for the clutch (CM stage 3), 1700 for labor. The above qoute for labor is right on.
Old Nov 22, 2009 | 05:51 PM
buzzm's Avatar
buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !
whats the cost of the sachs ?
if your not planning on modding beyond 550hp (approx) and like the stock clutch feel, would stock clutch be the best way to go ?
Old Nov 22, 2009 | 05:58 PM
MBailey's Avatar
If you really wont go beyond 550 crank hp, this clutch has an identical feel to stock. It easily held my car at 600 crank but failed quickly at 650 crank.
http://www.evoms.com/marketplace/Vie...002C337C06B%7D
If you think you might go above 600 crank I would recommend a stage 3 clutch.
Old Nov 22, 2009 | 06:15 PM
ezeks's Avatar
ezeks is infamous around these parts
I just got my car back from the shop on Friday and a new clutch was one of things it was in for. My indy got my Sachs stage 2 for 1700 and labor was 14.5 hrs for clutch and new flywheel install. As mentioned above the labor is a big piece of the equation so spend the extra $$ up front to put in a stronger clutch if you plan to upgrade your power at any point.
If you haven't done plugs it would probably be a good time as well since the car is in the shop, I would think at 51k they have probably been done once and may be almost ready to be changed again.
Old Nov 22, 2009 | 06:28 PM
buzzm's Avatar
how would you compare the feel of the sachs to the stock clutch ?
Old Nov 22, 2009 | 06:44 PM
ezeks's Avatar
pedal feel with the sachs seems very comparable to stock, however the sachs disk has much more bite to it. It definitaly is not a heavy feel and does not exhibit the on/off action of some clutches.
Old Nov 22, 2009 | 06:46 PM
bimmer81's Avatar
bimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to behold
you have pm
Old Nov 22, 2009 | 06:55 PM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
without a gt2 slave delete you shouldn't notice any difference on a power assisted clutch, with a gt2 slave delete the upgraded pressure plate would have more pedal resistance then the stock pressure plate.
if i was replacing the clutch i would go atleast to stage 2/3 setup kevlar or fibertuff
Mike knows hes used em before i would not put a stock organic disk back in too easy to smoke em.
Old Nov 22, 2009 | 07:50 PM
ard's Avatar
ard
I hate it when a clutch dies right after it has been to the shop....
Old Nov 22, 2009 | 08:11 PM
jags911tt's Avatar
jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !
I have a evoms stage 3 for sale with a LWFW and it have a carbon/kevlar plate. It only has 3000 miles on it. Ill make you a great deal if your interested.
Jag
Old Nov 23, 2009 | 07:08 AM
GoingFast's Avatar
Thanks everyone for your reply and IMs! I think I will go with Stage 1 since I will never mod my car above 550 hp - flash and exhaust are the only things I wanted to do to this car. I also like the feel of the stock clutch.
Any thought or comment on my choice?
Happy Thanksgiving and stay safe,
TC
Old Nov 23, 2009 | 08:01 AM
cybersam69's Avatar
cybersam69 is infamous around these partscybersam69 is infamous around these parts
I'm jealous of all you guys and your clutches that don't suck like mine. Stage 4 is killer with the on/off. I ALMOST looking forward to having to replace it with something that can handle 550-600HP and not be as brutal to drive.
Steven, you now know what I am talking about...
Chi, you need to drive my car sometime and feel it...
MrMiggy
Aug 21, 2015 06:55 PM
porsche4391
Nov 21, 2008 09:20 AM
