HELP - Leaking ABS Control Unit
Old Dec 8, 2009 | 10:57 AM
myfirstTT's Avatar
myfirstTT is infamous around these parts
So I had the Brake Fluid Level Light flash on me the other day, and pedal went mushy. Went in to have it diagnosed at a Porsche Dealer (since I was nearer there than my own shop). They said there was air in the lines, and then did a fluid flush/replace and bled the lines.
Took my car down to my regular shop to look at some other minor issues identified by the dealer - and my shop told me that I have a leaking ABS control unit and that this needs replacing. Apparently Porsche is on their 6th version of this part since the car was new and thus appears that this is a problem part for the 996TT.
Does anybody know any things I can check or do, or places I can look to avoid paying over $2k to replace my ABS Control Unit?
Thanks!!
Old Dec 8, 2009 | 01:46 PM
ard's Avatar
ard
There are folks that 'rebuild' the ABS modulator/pump... although I've never had to replace one. I'd frankly be very cautious with who does the rebuild.
I'd also ask the P dealer why they took $300 from you to service a system that was effectively 'unserviceable'.... (if the ABS is definitely bad)
A
Old Dec 9, 2009 | 07:05 AM
myfirstTT's Avatar
Yeah - my shop definitely tells me: "the ABS Control Unit is leaking - due to a broken/cracked seal inside".
I am in the process of getting the P Dealer to refund my money - I got charged for a diagnosis and a brake fluid exchange - they didn't find the source of the problem - and the fluid they put in didn't stay in, so hopefully, I can get them to refund!
Anyone have inputs on things I should physically check re: the ABS control unit??
Old Dec 9, 2009 | 08:55 AM
myfirstTT's Avatar
OK - so I got the ABS control Unit, but am also told that the Electronic Sensor (located under the console?) also needs to be replaced - as when you put a new ABS control unit in - the old Electronic Sensor will not read the new unit - and thus the ABS will not work.
Is this true? Are there workarounds for this? My shop says there are not, but want to know if others have done it themselves?
Old Dec 9, 2009 | 09:13 AM
UrbanHotrod's Avatar
UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !
I have a ABS unit that i bought that i do not need, I only needed the Module for mine.
The module is interchangeable you can reset the code with the Durametric. I am not 100% sure but if i put a used module on mine then i am sure it would be the same.
cinellipro
Dec 20, 2017 07:12 PM
DetomasoGTS74
Nov 11, 2015 09:01 AM
carwash
Sep 26, 2015 03:11 PM
I'mAllIn
Sep 11, 2015 06:38 AM
riozilla
Aug 21, 2015 11:34 PM
