headlight probme is this normal?
hi i notice this last night when i turned on my headlights only 1 low beam worked. then when i turn it off and turn it back on both works. and today i tried it again. 1 side worked. then i turned it off and turned it on both side works this is weird is this normal? or whats wrong?
If you have the MAF cleaning stuff remove the switch and spray some inside and just click the switch into all its settings this cleans it quite nicely. The contacts are just dirty, did this to mine just a month ago.
https://www.6speedonline.com/forums/...e-replace.html
This link is what I used to remove the light switch.
Feelgood MD
Mar 24, 2016 09:35 AM
The Youngn
Sep 10, 2015 12:24 PM
