Carbonetics LSD HELP
Old Dec 16, 2009 | 09:37 AM
EL750's Avatar
EL750 is infamous around these parts
My mechanic has received my Carbonetics LSD. The OEM bolts for the crown gear are a bit short (22mm) and only get 6 full turns, Is this enough or do I need longer bolts? With the stock diff I got 8 full turns.
Old Dec 16, 2009 | 09:51 AM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
contact guard lsd on here or one of the shops that works on porsche motorsports lsd's or the carbonetics team that designed it.
Old Dec 16, 2009 | 12:02 PM
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
Will the bolt tq to spec?
Old Dec 16, 2009 | 12:08 PM
EL750's Avatar
Haven't tried it yet. That is what Carbonetics said. If it does it's ok. My car has 800+ lbsft. I want to be safe. I already destroyed A 996CUP LSD.
Old Dec 16, 2009 | 08:01 PM
robmd99's Avatar
robmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond repute
Call Akram at Motorwerks. I have a similar setup on my car.
Good luck
Robert
Old Dec 17, 2009 | 04:39 AM
EL750's Avatar
Thanks guys. OEM bolts torqued@140lbs .
Old Dec 17, 2009 | 04:41 PM
so correct bolt n everything worked out howz the car like the diff?
Old Dec 17, 2009 | 11:32 PM
EL750's Avatar
The LSD has been installed in my secnd tranny with taller 1sr,2nd, and 3rd gers. It,s going to be a while before I swap the gearbox. I'll let you know when it's done.
Old Dec 18, 2009 | 01:01 AM
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
Did the Hat break away from the diff?
Old Dec 18, 2009 | 01:09 AM
EL750's Avatar
Yes. It started making some noise under accel. and the following day it just broke away. It only lasted 2-3000 miles.
Old Dec 18, 2009 | 02:52 AM
I managed to get my hands on the Ultra rare RSR Diff... it's similar to Cup but a Billet Diff... I narrowed it down to this or the Guards, personally I think that's the only 2 that are up to the job for our high Torque motors.
Old Dec 18, 2009 | 07:52 AM
EL750's Avatar
The RSR is very aggressive, but strong. I guess it all depends on your power and application.
Fadi
Aug 17, 2018 05:16 PM
csmrx7
Jun 19, 2018 01:08 AM
Mark @ AIM Performance
17
Jan 22, 2016 07:53 AM
Saint Ari
Sep 8, 2015 08:47 PM
Saint Ari
Sep 7, 2015 07:09 PM
