too many type ii over revs?
Old Dec 25, 2009 | 08:23 PM
  #31
BarryP's Avatar
BarryP is infamous around these parts
Originally Posted by GT3 Chuck
I'm not sure the rev limiter not keeping up is the problem...it is entirely possible that the momentum created by all the rotating mass (especially in a awd) when the wheels break traction at high rpm could result in a mechanical over-rev...but as you say, same result, a type two is registered...if the rpm redline can be safely upped to 7,000 then the type II over-revs shown would not be as serious...it is too bad that the 996 doesn't log the rpm range of the over-rev like the 997 cause there is no way to tell if that over rev was at 7,000 or 8,500 rpm
I wonder if log can be added to the 996 program to capture the over rev rpm? It would be a nice feature to have if your car has been modified.
Old Dec 25, 2009 | 11:28 PM
  #32
aroonkl's Avatar
aroonkl is a jewel in the rougharoonkl is a jewel in the rougharoonkl is a jewel in the rougharoonkl is a jewel in the rough
Wow. If I have a flash with 7000rpm rev limit and I change gear accordingly, I would end up with ton of Type II over rev. Do I understand correctly?
Old Dec 26, 2009 | 10:29 AM
  #33
wross996TT's Avatar
for your edification...I have never said you couldn't get a type II without a missed downshift...secondly, I have explained how spinning the wheels can result in a mechanical over rev which in a 996 will register a type II...certainly, raising the rev limit by flashing or tuning will result in lots of type II's on a 996 and those would not result in the damage a missed downshift would likely cause...so your condescension is not necessary
here is your first quote
since a Type II is supposed to be a mechanical over-rev I am curious as to how you can register a type II by breaking traction since the rev limiter should preclude the engine from going past redline
I guess I need some english language classes as this sounds like you don't think type 2's can be caused by anything but a mechanical...the links I added provide evidence which disputes this claim...not just internet conjecture. It was you that took one sentence out of the links I posted (which you called my thread...a bit condescending as well...)
A Type 2 is an o... (from your own thread) LOL
. If you post something without supporting evidence, just your hypothesis, be prepared to be challenged...I suppose you interpret LOL differently than me.
Old Dec 26, 2009 | 06:44 PM
  #34
Turbo Fanatic's Avatar
Yes. Again, I think too much is made of this.
Some tuners reset the redline at 7400+ I can't see how an over rev or 100 to 6701 RPM is scary.
Needsdecaf
Cayenne 958
10
Oct 12, 2015 03:05 AM
007 Vantage
Oct 8, 2015 08:35 PM
TOGWT
Detailing
Oct 1, 2015 07:59 AM
00aston
Sep 28, 2015 08:08 AM
