Car dies when comming to a stop in neutral
Old Feb 7, 2010 | 09:47 PM
  #31
RinLV's Avatar
RinLV is infamous around these parts
When my boost hose from the intercooler had a small leak, I had similar problems... FYI
Old Sep 18, 2013 | 07:13 PM
  #32
slowlude22's Avatar
slowlude22 is infamous around these parts
Back from the dead, but what was the issue here?
I'm having a very similar problem with my turbo. Thanks.
Old Sep 18, 2013 | 07:45 PM
  #33
raineycd's Avatar
Probably a vac line leak or some other line off.
Old Sep 18, 2013 | 08:09 PM
  #34
very possible its the LWFW....
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Sep 19, 2013 | 07:46 AM
  #35
mtlsp's Avatar
mtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond repute
not a guru but try disconnect the battery for 5 minutes or more the DME will go back to it's basic program. It will then re-learn to your driving style and maybe adapt to your new mods
good luck
Old Sep 19, 2013 | 12:20 PM
  #36
SSMugen's Avatar
SSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond repute
I had a very similar problem when my revs dropped sometimes the car would just die. I remember a specific off ramp where this happened a few times at the exact same spot. I would go from 3rd to neutral and it would just die heading straight into a corner which was a bit scary. I switched to a mafless tune by protomotive about 6 months ago and haven't had the car die since. Also car runs much smoother.
Old Sep 20, 2013 | 01:21 AM
  #37
teflon_jones's Avatar
teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !
Originally Posted by f1crazydriver
It wasent a garage queen, use to be my DD until i bought a Smartcar.
And there's your problem right there! It's not happy about the Dumbcar being your new DD!
Old Sep 24, 2013 | 09:14 PM
  #38
calfrank's Avatar
calfrank is infamous around these parts
Had the same problem earlier this year. Sometimes when i'm coming to a stop, when i depressed the clutch, the car would shut off. It got worse overtime. Replaced the MAF sensor but it didn't help. It turned out to be the throttle body. It needed cleaning! Buy a bottle of throttle body cleaner, clean the throttle body and the inside flap well. You will find some grease/oil there. Since then, no more problems, car idles smooth and it doesn't shut off anymore. Hope this helps!
Old Nov 5, 2013 | 10:11 PM
  #39
slowlude22's Avatar
I ran a boost pressure test and it's holding fine. I'll try cleaning the TB.
I'm running a LWFW on an older evoms gt640 setup. I assume there might be a tune update that would help as well. Thanks for the tips.
Old Nov 6, 2013 | 09:27 AM
  #40
f1crazydriver's Avatar
f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !
I replaced the brake or clutch switch under by the pedals.. i have an extra ill look for part number.. that fixed the issue about 70%... I got the TB replaced and everything else cleaned in that area by the dealer and everything was 99% good from there on..It only happened as is once in awhile so it never really bothered me, but it was sometime in the worse moments.
I had the UMW flash and UMW lwfw kit.
Senatorblutarsky
Aug 28, 2015 12:44 PM
gulf gt
Aug 27, 2015 10:27 AM
DerekShiekhi
Other British Cars
Aug 19, 2015 05:25 PM
saline
Aug 19, 2015 12:25 PM
