2002 Suspension Upgrade - what would you do?
Old Dec 31, 2009 | 08:52 AM
vividracing's Avatar
Best setup is this for you...
Bilstein PSS10
H&R Rear Sway Bar
NOTHING else
Old Dec 31, 2009 | 09:28 AM
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
Originally Posted by boca996tt
is there a brand of sways that are best.. ? want something that just bolts right in with out switching a bunch of other parts.. dog bones etc.
All of the bars will fit, they all just bolt in, and I don't think that there is a lot of difference between them. You don't need any other suspension parts, except for drop links.
You should get drop links with adjustable heim joints - stock links are fixed length. This is essential for the front, where there isn't a lot of clearance for the bar between the axle and the lower control arm. If you adjust the height af the car, you need to also be able to adjust the length of the drop link to avoid interference on these two parts. GMG, Tarrett, TRG and others have been used successfully.
I adjust the length of the drop links like this:
> Tighten the upper joint, leaving the bottom one out of the bar
> Lower the front wheels onto ramps so that the front is fully loaded, but you can still get underneath.
> Adjust the sway bar until it is about 1/3 of the way up from the lower control arm.
> Adjust the drop links' length so that they fit easily into whichever hole you want to use.
> Turn steering to full lock in each direction to be sure the bar doesn't rub the axle, then tighten the links and jam nuts
On a scale of 1-10, this job is a 2.
Old Dec 31, 2009 | 11:38 AM
landjet's Avatar
Originally Posted by boss351
Call Fabryce at GMG racing
I agree. GMG is a full race shop that knows their stuff.
Old Dec 31, 2009 | 01:13 PM
joe731's Avatar
joe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to behold
Who are the top 2-3 suspension tuning shops located in the New York Tri-state area? I am 2 hours Northwest of NYC.
Old Jan 2, 2010 | 03:12 AM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
Originally Posted by Mikelly
This is actually not 100% accurate. My car has PSS9s and with the stock rear suspension we were able to pull as much or as little camber as we needed (up to -2.2) on a GT2 ride height (my car is an 01TT). In order to get to my track settings of -3.0 front and -2.5 rear, you'd need dogbones and GT3 lower control arms, along with other useful stuff. But for an agressive street alignment, he shouldn't need it, even at GT2 ride heights.
Also, knowing what I now know about how soft the driveline bushings are. I'm not sure I wouldn't put upgraded tranny and motor mounts on the list AHEAD of suspension upgrades.
I'm with heavyChevy on this one... I'd do the PS10s, some HR Swaybars with upgraded HEIM JOINT style drop links and a good alignment.
On a side note, has any one had luck getting the tarett drop links to be a little more quiet.
Make sure you get the car set up properly. A good suspension guy is worth his weight. I personally recommend getting a car scaled, but some will chime in and say "It's a street car, don't worry about it". Scaling the car will allow the suspension engineer the ability to equalize the static load right to left on each axle/end of the car. Ride height is only a part of the equation. Getting someone in your area experienced with 996s is great, and if they have TT experience, even better. We are using Michelin PS RIBs and I've had great luck running more aggressive alignment with the car... I'm able to run -1.5 camber up front and -2.0 on the rear with stock caster, along with toe recommended by your shop. I run zero toe on my setup, but it's "twitchy" and "nervous" feeling for some. Some toe is a good thing for street only driving.
Call it done after that, unless you plan to track it. Then if you do, still, don't do anything beyond good rubber until you're an intermediate to advanced student...Then we can give you a whole list of ways to spend your money!
Mike
Mike,
You had much more luck with rear camber than I did. I was stuck at negative 2.5 camber (great for the track but destroyed inner tire edges on the street) and couldn't pull anymore positive camber out of the stock eccentrics. It could be the 19" with 325's on the back that contributed to the problem. I needed the dogbones to put less camber in the back. The dogbones have the added advantage of limiting camber changes during aggressive driving. Althought not cheap, they are a bargain compared to having to buy a set of rear tires and having a corner balance and alignment done twice.
On a side note, has any one had any luck in getting the tarett drop links to be a bit more quite?
Old Jan 2, 2010 | 04:18 AM
Mikelly's Avatar
Duane, That's helpful information to include in a suspension post. It is definitely the 19s/tire size combo effecting your lack of camber adjustment. The eccentrics have a range based on the specs of the OEM tire height and width (P-Zeros). Beyond that and all bets are off!
For the Tarred Drop links, are yours clanking or squeeking? For squeeking we used white lithiium grease. For the clanking, we found that the angle was slightly off and making slight contact with the control arm. Simple adjustment took care of that!
Mike
Old Jan 3, 2010 | 03:15 PM
REVS11's Avatar
REVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond repute
Go for Eibach. Fits perfect with stock links and PSS9 or 10 and car behaves REALLY good, on street, and track.
Old Jan 3, 2010 | 06:02 PM
landjet's Avatar
I have the TRG drop links. No noise, very stout.
Old Jan 6, 2010 | 08:53 PM
Zippy's Avatar
Same
Old Jan 6, 2010 | 09:19 PM
wrasse's Avatar
wrasse is infamous around these parts
I have PSS10s only set at GT2 ride height with corner balance and they are pretty much perfect for street use.
Old Jan 7, 2010 | 03:09 AM
heron163's Avatar
heron163 has a reputation beyond reputeheron163 has a reputation beyond reputeheron163 has a reputation beyond reputeheron163 has a reputation beyond reputeheron163 has a reputation beyond reputeheron163 has a reputation beyond reputeheron163 has a reputation beyond reputeheron163 has a reputation beyond reputeheron163 has a reputation beyond reputeheron163 has a reputation beyond reputeheron163 has a reputation beyond repute
Bilstein PSS10
H&R Rear Sway Bar
NOTHING else
and GT2 ride height or what setting?
thanks!
Old Jan 7, 2010 | 02:15 PM
gpsupra's Avatar
gpsupra is infamous around these parts
What do you think of the Pss10's. i am looking for coilovers and cant decide
Old Jan 7, 2010 | 02:22 PM
landjet's Avatar
How do you plan to use the car? Street, track, combo?
Old Jan 7, 2010 | 02:33 PM
TT Gasman's Avatar
TT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant future
Get a rear GT2 sway bar, it's a direct bolt on, OEM quality, and not too expensive. That way you can dial out some of the understeer.
Old Jan 8, 2010 | 11:06 AM
S4corrado996TT's Avatar
S4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really nice
Great discussion! BTW where can I get Tarret or TRG drop link? Tks to all!
