Need Specs on 996 Turbo MAP Sensor
Old Jan 9, 2010 | 08:21 AM
ShokWaveRider's Avatar
ShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to all
Does anyone have the ACTUAL Voltage Output vs Pressure of the OEM MAP Sensor on the 996 Turbo X50 or S?
996-606-180-00-M14 it is a 0 261 230 042
This is what mine reads, I just took it out and measured it on the bench with 5v applied.
1psi =1.92v
5psi = 2.53v
10psi= 3.2v
15psi = 3.86v
20psi = 4.5v
22,5psi = 4.84v
Thanks in Advance
SWR
Old Jan 9, 2010 | 11:31 AM
Tony@epl's Avatar
Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !
1psi =1.92v
5psi = 2.53v
10psi= 3.2v
15psi = 3.86v
20psi = 4.5v
25psi = 4.84v
30psi
Thanks in Advance
SWR
The oe sensor is sold through Bosch Motor sports with a different part number. My guess is with a little "google" work, you can fine the specs of the bosch motorsports unit.
1.55 bar should equal about 4.9 volts... Keep in mind that the stock sensor can only ready to 2250 mbar, so your 25psi data is actually more like 22.5 psi.
Old Jan 9, 2010 | 11:53 AM
You are correct: It is a 250kPa sensor as you say 22.5psi. There seems to be about a 10% Deviation on it though, or at least mine. I based my calculating on 19psi anyway as that is the extent of my X50 Flash.
Old Apr 3, 2012 | 05:43 AM
jonty's Avatar
jonty is a name known to alljonty is a name known to alljonty is a name known to alljonty is a name known to alljonty is a name known to alljonty is a name known to all
So is this a 2 bar sensor then or 3 bar given ambient pressure?
Old Apr 3, 2012 | 01:22 PM
pete95zhn's Avatar
pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !
http://almisoft.ru/files/bosch_map.pdf
It's 250kPa = 2500hPa = 1.5 bar boost.
Old Apr 3, 2012 | 02:28 PM
jonty's Avatar
I think it is 2.5 bar as 1 bar is ambient pressure so it reads 1.5 bar above ambient or 2.5 bar total range?
BlackMarketRacing
Dec 8, 2015 01:49 PM
Perkman87
Nov 19, 2015 05:31 PM
PelicanParts.com
996 Turbo Vendor Classifieds
Aug 20, 2015 02:40 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
PelicanParts.com
Aug 18, 2015 03:43 PM
