Tpms??
Old Jan 17, 2010 | 05:04 PM
Turbo Fanatic's Avatar
Tpms??
I'm going to replace my rear tires soon and am considering an aftermarket TPMS.
I remember seeing one person do an install right inside the ashtray... Any recommendations on brand, install, costs...
These 25 series tires seem so fragile. I'm always checking the pressure...
Old Jan 17, 2010 | 05:15 PM
GoingFast's Avatar
GoingFast is infamous around these parts
I read here that Orange is a good system to get and there was a group buy last year. Here is the link I bookmarked. I hope this help. I am debating should I do it or not since I will replace all 4 tires when summer comes.
http://www.gotogroupbuy.com/260/Oran...Group-Buy.aspx
http://www.orange-tpms-usa.com/sub01.asp
Old Jan 17, 2010 | 05:55 PM
oatmealadam's Avatar
oatmealadam is infamous around these parts
I'm running a 25 series on the rear as well, I guess every little bump causes further air loss. I have since gone back to OEM size and the ride is much nicer now.
Old Jan 17, 2010 | 06:07 PM
Patrnflyr's Avatar
Patrnflyr has a brilliant futurePatrnflyr has a brilliant futurePatrnflyr has a brilliant futurePatrnflyr has a brilliant futurePatrnflyr has a brilliant futurePatrnflyr has a brilliant futurePatrnflyr has a brilliant futurePatrnflyr has a brilliant futurePatrnflyr has a brilliant futurePatrnflyr has a brilliant futurePatrnflyr has a brilliant future
I just ordered mine from Amazon for $139.00 for the model P409S. It's a little more than the group buy, but that's about the best price I've seen. They say it should fit the HRE's I just put on. Now, I just need to figure out where to put the little monitor since I just installed a double DIN radio and there's not alot of room. Here's a link to that site if you're interested:
http://www.amazon.com/Orange-Electro.../dp/B002DYH586
Hope this helps...
Old Jan 17, 2010 | 06:08 PM
w00tPORSCHE's Avatar
w00tPORSCHE has a reputation beyond reputew00tPORSCHE has a reputation beyond reputew00tPORSCHE has a reputation beyond reputew00tPORSCHE has a reputation beyond reputew00tPORSCHE has a reputation beyond reputew00tPORSCHE has a reputation beyond reputew00tPORSCHE has a reputation beyond reputew00tPORSCHE has a reputation beyond reputew00tPORSCHE has a reputation beyond reputew00tPORSCHE has a reputation beyond reputew00tPORSCHE has a reputation beyond repute
BERU brand makes one of the best TPM sensors and several car manufacters use them for their stock sensors.
Old Jan 17, 2010 | 10:52 PM
Just need to know if they will fit my 19" champions RG19s
BTW the picture above is indeed an orange system...
Old Jan 18, 2010 | 07:06 AM
ShokWaveRider's Avatar
ShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to all
Here it is on ebay.
http://cgi.ebay.com/ebaymotors/Orang...Q5fAccessories
$110 + shipping.
I think we need special valves for the Porsche.
Old Jan 18, 2010 | 07:19 AM
PrecisionPorsch's Avatar
PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !
Ari,
I have them on my 360 Forged Mesh8's and on my other wheels on my daily driver. Both wheels, I had to get these adaptors
http://www.iforged.com/store/index.p...6f238c60ca73ca
Edwin
Old Jan 18, 2010 | 08:20 AM
Patrnflyr's Avatar
I was told I didn't need any special adaptors for the HRE's. I've got an email to them to find out if they are needed.
John
Old Jan 18, 2010 | 08:51 AM
dfwerdoc's Avatar
dfwerdoc has much to be proud ofdfwerdoc has much to be proud ofdfwerdoc has much to be proud ofdfwerdoc has much to be proud ofdfwerdoc has much to be proud ofdfwerdoc has much to be proud ofdfwerdoc has much to be proud ofdfwerdoc has much to be proud ofdfwerdoc has much to be proud ofdfwerdoc has much to be proud of
john who did you contact at hre or orange to find out if your wheels were compatible? i have a set of c93's ordered and i want to add the tpms to it? thanks
Old Jan 18, 2010 | 08:53 AM
Nigel P Nunn
Orange Electronics USA
5765 State Rt. 48
Building 110 Suite 186
Maineville, Ohio 45039
ph-
53-831-8767
fx-513-831-0730
Old Jan 18, 2010 | 09:06 AM
Patrnflyr's Avatar
I went on the HRE website and went to "contact us". Should hear back within 24hrs. Also, I just talked to Nigel at Orange. Super guy, BTW. He said that you just need to try the stock ones first because alot of wheels fit with stock TPMS. He said you will know the second you try and they have a set of adaptors that they can get to us quickly if needed if it doesn't fit. Also, he asked me to mention on the forum that most people are mounting the monitor in the center console behind the power windows and ahead of the cab switches in that spot. He asked to keep the power cable as long as possible since it also acts as an antenna. Alot of people find a real close 12 volt source and clip the wires short losing some RF ability. Also, he said when you clip the cig lighter adaptor to hard wire the unit, there are 3 wires, a red, green and black. He said connect both the red and green to positive and the black to the negative. Hope this helps!
John
Old Jan 19, 2010 | 12:23 AM
Got a call in to Orange. Ideally i'd liek to get 8 TPMS valves for stock and 18" wheels and 1 in-car module.
Will update
Old Jan 19, 2010 | 03:32 PM
Patrnflyr's Avatar
They emailed me back late last night and said that the P43's shouldn't be a problem with the stock opening for the valve stems.
John
Old Jan 19, 2010 | 07:58 PM
fdorn's Avatar
fdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud of
For confirmation on the wiring:
https://www.6speedonline.com/forums/...ange-tpms.html
Specifically
https://www.6speedonline.com/forums/2468023-post6.html
I know in the past there was an issue with fitment and the hollow turbo twists. I have solid and they fit perfect. Nigel was working on adapters before but I dropped out of the thread after mine were installed and don't know the resolution.
The Hecla model that TireRack now sells is higer quality, but the Orange has never failed. It is deadly accurate for both psi and temp.
Good luck
John
