Drag racing set up
Old Jan 28, 2010 | 11:28 PM
Racin Jason's Avatar
Racin Jason has a brilliant futureRacin Jason has a brilliant futureRacin Jason has a brilliant futureRacin Jason has a brilliant futureRacin Jason has a brilliant futureRacin Jason has a brilliant futureRacin Jason has a brilliant futureRacin Jason has a brilliant futureRacin Jason has a brilliant futureRacin Jason has a brilliant futureRacin Jason has a brilliant future
Drag racing set up
Looking to take a 996tt to the local street drags. I have lots of experience running bikes and domestics but no p car seat time.
Besides the obvious; removing extra weight 1/2 tank of gas etc. What tips can you guys give me so I don't blow it?
Launch rpm etc?
The car is rwd and makes 550hp at the wheels.
Thanks in advance!!
Old Jan 29, 2010 | 05:19 AM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
get tire pressure right, probably could setup the rear suspension to give a more flat contact patch, get some axles cause the stock ones will break if thats all your gonna do is 1/4mile and practice. i dont expect your clutch to last too long either.
Old Jan 29, 2010 | 07:04 AM
WOODTSTER's Avatar
Myself and others did lots of runs with much more power than that.
Here is a "soft launch" that I did (not a drag race obviously), but it can be done
without decimating your clutch but certainly will shorten its life.
The guys with the really good times have run 17" drag radials (or 18" at least).
My runs were always run on 19" Mich PS2's (which is less than ideal).
Practice, Practice, those launches and shift points !
http://www.youtube.com/watch?v=qmvVyM1UPDo
Old Jan 29, 2010 | 08:08 AM
UrbanHotrod's Avatar
UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !
Tires are a very big part as well as Launching. Good luck.
Old Jan 29, 2010 | 10:04 AM
thanks for the replies guys!
What launch rpm should I start with?
Old Jan 29, 2010 | 03:18 PM
ttboost's Avatar
I launch around 3000-4000 or so and slide it out nice and easy... NO dumping the clutch!!!
I still spun in first and bogged 2nd...
http://www.youtube.com/watch?v=UyFdggOYILI
http://www.youtube.com/watch?v=05J094SK1Lk
Old Jan 30, 2010 | 12:54 AM
Obbie1's Avatar
Obbie1 is infamous around these parts
ttboost - what axles and clutch are you using?
Old Jan 30, 2010 | 06:00 AM
ttboost's Avatar
Stock axles,(that's why I am not launching) and a Clutchmasters Stage 3ish clutch. It's actually a Stage 3 clutch with a little more spring pressure for holding power and a LWFW. The LWFW makes it very hard to launch, but very noticeable improvement under acceleration.
Old Jan 30, 2010 | 06:53 AM
btapp's Avatar
btapp is a glorious beacon of lightbtapp is a glorious beacon of lightbtapp is a glorious beacon of lightbtapp is a glorious beacon of lightbtapp is a glorious beacon of light
Nice driving.. That track looks perfect! Not crowded and a great local strip. I wish I had a good one nearby. Ours are all crowded, etc.
Old Jan 30, 2010 | 07:28 AM
2muchtime's Avatar
2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute
ttboost what % meth are you running? HFS6 or 1? curious
Old Jan 30, 2010 | 04:40 PM
ttboost's Avatar
Track actually bites. RARELY has traction. In that video, I have drag radials on, left as easy as I could and spun most of the way through 1st so bad I had to shortshift and bogged 2nd (as you can hear in the vid)
I am running 100% VP M1 methanol on an older HFS-1 Aquamist kit. I run the kit off of injector duty cycle. I did the install (even though EPL could have) and Tony did the tuning. Car runs awesome and has been VERY reliable at the 600whp level for quite a while now.
Old Jan 30, 2010 | 06:50 PM
dk996tt's Avatar
dk996tt has much to be proud ofdk996tt has much to be proud ofdk996tt has much to be proud ofdk996tt has much to be proud ofdk996tt has much to be proud ofdk996tt has much to be proud ofdk996tt has much to be proud ofdk996tt has much to be proud ofdk996tt has much to be proud of
the trick is to set up the car so you wont abuse the drive train, or else you will have to start replacing parts quickly. most tuners now offer the two step anti-lag launch control on the ecu. use anti-lag at around 5000 rpms and just slip the clutch out gradually. it is a very non-eventful launch with good results. here is mine with a 60 ft time of 1.66 seconds.
http://www.youtube.com/watch?v=r5xMyVaqtkU
Old Jan 30, 2010 | 07:14 PM
Turbo Fanatic's Avatar
EPL Offers launch control as part of their tuning package. I think that's your best bet if you're concentrating on drag racing. The system is like having a secondary rev limiter when in first with the clutch depressed... I imagine a pretty low primary limiter say 3,000 RPM is plenty to get the turbos spooling without beating your clutch.
I'm sure Tony knows what a good launch control RPM limit is..
Old Jan 30, 2010 | 08:02 PM
ttboost's Avatar
I have it and have tried it. It is and can still be tough on your drivetrain if you don't have a decent clutch. My has been set at 4k and it does work.
Old Jan 30, 2010 | 08:27 PM
John@SpeedTech's Avatar
Here is a moderate launch on street tires, awd, GT3 seats. Subwoofer, tool kit, spare tire removed - roll bar, 6 point harness added.
http://videos.streetfire.net/video/1...rag_130301.htm
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
