Memory Recall Buttons
Old Jan 30, 2010 | 09:52 PM
z4met's Avatar
z4met is a name known to allz4met is a name known to allz4met is a name known to allz4met is a name known to allz4met is a name known to allz4met is a name known to all
I have the two buttons by the driver door sill for recalling the memory settings for the seat/mirrors etc. The problem is that you must hold the button down while everything is adjusting to the recalled position. If you let it go, all the movement will stop.
Is there a way to modify it so you just have to press it and release it and everything will adjust to the recalled setting? I find that as the seat is moving forward while I am holding the button, the space between the seat and buttons are tight and my hand gets squished. A press and release feature would be much better.
Thanks,
Z4MET
Old Feb 1, 2010 | 03:38 PM
XLR82XS's Avatar
I don't think so. The CTT (04) does the same thing.
Old Feb 1, 2010 | 03:46 PM
2muchtime's Avatar
2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute
My CTT is 04' I noticed if I hold the button a little to long then I have to hold it until it is finished, if I tap the button I can release it and it finishes moving by itself?? I haven't tried it yet in my 996TT? I am the only driver so nothing ever needs adjusting.
Old Feb 1, 2010 | 04:06 PM
RiA's Avatar
RiA
RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !
You can program your key fob to set the positions. If you change the seat position, hit the unlock button on your fob (once programed) and your positioned will be set without having to hold the button.
Old Feb 1, 2010 | 06:02 PM
z4met's Avatar
True enough about the key fob, thats a good point. My problem is that I want the seat all the way back when I enter/leave the car to make ingress and egress easier. Once seated, I want the seat to move to the normal driving postion.
...Z4MET
Perkman87
Nov 19, 2015 05:31 PM
