Race Gas Question
Old Feb 2, 2010 | 06:41 PM
911 RV's Avatar
911 RV is infamous around these parts
Race Gas Question
What brand and octane are most using for your race file tunes on high boost (1.2 bar & up). I am in Northern Ca. and can get most brands and octanes. I was told no leaded as it will ruin the cats.
I spoke with Todd at Protomotive and he recomended VP103 unleaded.
What are you guys out there using.
Advice please.
Old Feb 2, 2010 | 06:53 PM
ttboost's Avatar
VP race fuel. MS109 for most boost levels, and C16 for bigger boost.
Old Feb 2, 2010 | 06:54 PM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
VP MS109 and Sunoco 260 GT Plus
Old Feb 2, 2010 | 07:31 PM
PAULIEWALNUTS's Avatar
PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !
MS 109 up to 1.6 bar. Damn Mike how much more boost is needed for C16?
Old Feb 2, 2010 | 07:32 PM
ttboost's Avatar
You know...BIG boost...geez...1.6 is still pump territory...
Old Feb 2, 2010 | 08:18 PM
onelove's Avatar
onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !
VP MS109 will be fine for most "street cars". C16 is great with custom tuning (Big Boost or extra timing).
Old Feb 2, 2010 | 08:25 PM
911stripper's Avatar
911stripper has a spectacular aura about911stripper has a spectacular aura about
mike,
does race fuel actually help when you have meth injection ?
thanks,
brian
Old Feb 2, 2010 | 10:00 PM
unvmy996's Avatar
I run ms 109 pretty much at all times
Old Feb 2, 2010 | 10:12 PM
dg123's Avatar
dg123 has a spectacular aura aboutdg123 has a spectacular aura about
vp 109
Old Feb 2, 2010 | 10:42 PM
AWD Motorsports's Avatar
AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !
I cant stand giving up $$$ to that Rip off VP.. Overpriced fuels.. 2.20/gal E85.. Of course you need the fuel system to support it and tune..
Mike
Old Feb 2, 2010 | 11:19 PM
depending on what set up you run the fuel does change... hence, if you run only a 18g set up with a greddy on a 5 bar 100 or 104 octane will be fine for 1.3 to 1.35 bar... no need for more expensive fuels as the added octane will not help you with the maxed out fuel system.... However, if you have a dual pump /injector upgrade etc then the higher the octane generally speaking the better the results....
markski
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Feb 3, 2010 | 04:15 AM
ttboost's Avatar
Originally Posted by 911stripper
mike,
thanks,
brian
Yes, but for me, not enough to waste $10/gal fuel driving around most of the time. On the dyno, the difference between pump-100% meth and MS109-50/50 was about 25whp and about 25-30wtq. I'm sure the more boost you run, the more of a difference it will make. I am running 1.3-1.4bar.
Old Feb 3, 2010 | 08:54 AM
im running 1.3 to 1.4 bar with 50% meth on pump gas. im not sold why i would want to run race gas ???
Old Feb 3, 2010 | 09:12 AM
bmoores's Avatar
bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !
Paulie you are running 1.6 bar?!?!
Old Feb 3, 2010 | 10:10 AM
Ben not me, i'm sayin some people run up to 1.65 on MS109. I think we both know of whom I speak.
