Funny Smell
Old Feb 7, 2010 | 05:23 PM
Hogapalooza's Avatar
Hogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond repute
Sonic burger under the seat?
Old Feb 7, 2010 | 06:03 PM
Prche951's Avatar
it could also be left over oil on a manifold from the work and it is burning off. Check under the truncklid where the pentosin reservoir is. If it is wet on the cap, then it may be a pentosin issue, accumulator or part of the system. Pentosin is not only flammable but corrosive. It will degrade rubber and plastic real bad. Also if your accumulator is going bad, you may feel a gritty type of clutch. But check for leaks before you start the car again. lift it up and go under it, check for wetness in back.
Jd1368
Oct 16, 2015 09:48 AM
Batman-76
Sep 22, 2015 09:08 AM
Lucid Moment
Sep 12, 2015 01:12 PM
JSF721
Detailing
Sep 8, 2015 07:57 AM
