fvd flash..
Old Jul 13, 2010 | 10:13 PM
LO_996tt's Avatar
LO_996tt is infamous around these parts
how do you tighten wastegates? DIY somewhere?
Old Jul 14, 2010 | 03:13 AM
dixie's Avatar
dixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to all
Really easy,just make 2 turns clockwise and you should get 0.1 more boost
Old Jul 21, 2010 | 12:48 PM
PacMan Z's Avatar
PacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud of
Which bolt? Nearest the actuator or opposite of it?
Old Jul 21, 2010 | 02:34 PM
dixie's Avatar
Both bolts
Old Jul 21, 2010 | 05:49 PM
drhenrock's Avatar
drhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to behold
Had FVD, DV, and dropin, was seeing 1.0-1.1 in all gears. Now w/ dual intake, Y-pipe, TB, plenum and IC's seeing 0.9 max, told that was normal. Smoke test was done no leaks.
Old Jul 21, 2010 | 06:06 PM
Yves's Avatar
Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !
I see 0.8 bar up to second gear, up to 1.3 bar as of 3rd gear, as of which the car runs like a raped ape. I do have zero clearance hybrids (16/24).
My buddies in normally aspirated GT3s (who see me dissapear in the distance ) tell me there's black puffs of smoke when I hit it hard. Car is definitely running too rich.
Old Jul 22, 2010 | 07:30 AM
dixie's Avatar
I have K16/24 with FVD flash,always see 1-1.1 bar,I also changed to a dual intake,TB and plenum and IC's and still see 1-1.1 bar ( don't have the Y pipe)
Old Jul 22, 2010 | 10:49 PM
aroonkl's Avatar
aroonkl is a jewel in the rougharoonkl is a jewel in the rougharoonkl is a jewel in the rougharoonkl is a jewel in the rough
Why .8 in 2nd and 1.3 in 3rd.? If your turbo is big, it would be reasonable. Might worth to check. Something is not right.
Old Jul 24, 2010 | 04:28 PM
drhenrock's Avatar
Have you adjusted the Wastegates? I called FVD and they said w/ my set up I should only see .9bar...?
Old Jul 25, 2010 | 07:32 AM
dixie's Avatar
I didn't adjust the wastegates,but if I were you I would turn your bolts from the wastegates 2 turns clockwise and see what happens.
wrs
Nov 17, 2016 06:53 AM
Pbread
Jul 23, 2016 08:00 PM
30vQuattro
20
Dec 4, 2015 05:26 PM
gadgetman
Sep 10, 2015 11:33 AM
