fvd flash..
Old Feb 13, 2010 | 03:24 PM
boca996tt's Avatar
boca996tt is just really niceboca996tt is just really niceboca996tt is just really niceboca996tt is just really nice
fvd flash..
anyone here have a reflash done by FVD? just wondering how much boost your seeing on your dash...
Old Feb 13, 2010 | 05:08 PM
smithk3933's Avatar
smithk3933 has a spectacular aura aboutsmithk3933 has a spectacular aura about
I've only had my car for 1 month but so far I'm seeing .9-1.0 on the built-in boost gauge with the FVD flash.
Keith
Old Feb 13, 2010 | 05:24 PM
boca996tt's Avatar
you have a tip or 6 speed? K16's turbo's?
Old Feb 13, 2010 | 06:43 PM
Turbo Fanatic's Avatar
You shopuld get a solid 1.0 on K16s with most flashes. Tighten your stock wastegates 1/4 to 1/2 turn if you're not usually seeing 1.0
Old Feb 13, 2010 | 06:46 PM
boca996tt's Avatar
I think I only saw a 1.0 bar a few times but it was only for a second, mostly only see .8 & .9 for some reason I think my car is running too rich.. my exhaust tips get BLACK in one drive
Old Feb 13, 2010 | 09:38 PM
smithk3933's Avatar
At what RPM should max boost be reached or between what range? Mine is a 6 speed with the stock K16's.
Keith
Old Feb 14, 2010 | 03:01 AM
dixie's Avatar
dixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to all
I have FVD flash and K16/24 and always have 1 - 1.1 bar ,I had 4 different flashes but like FVD the most.At full throttle A/F is always between 12 and 12.3 so certainly not to rich.In 1st,2nd,3th and 4th gear boost is 1 bar and 5th and 6th gear boost is most of the time 1.1 bar.
Old Feb 14, 2010 | 03:10 AM
dynamic gt2's Avatar
dynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to behold
You can see 1bar in first gear!!
Old Feb 14, 2010 | 08:16 AM
dog4delta's Avatar
dog4delta is infamous around these partsdog4delta is infamous around these parts
With FVD flash on my '03 (6-speed manual) I saw a steady 1.0 and occasionally 1.1 during WOT in higher gears. I recently upgraded the flash for K16/16G turbos with a 5-bar FPR and now get a solid 1.1 and generally 1.2 in higher gears. My exhaust tips do get some carbon buildup, but the AFR looks good on the dyno, and my mileage is still about 18 in town and 22 on the highway if I can manage to keep my foot out of it most of the time. Have you upgraded your DVs or are they stock?
Old Feb 14, 2010 | 08:25 AM
boca996tt's Avatar
I dont think my car is getting the same boost levels.. maybe my stock plugs are not good for the flash? I have aftermarket DV's I believe EVOMS.. most of the time I only see .8 maybe .9 boost levels, and I seem to use a lot of fuel..
Old Feb 14, 2010 | 09:39 AM
dog4delta's Avatar
If your plugs were bad, you'd probably be tripping codes and feel the car missing. I'm not sure what state you are in. I'm in TX as my file was built for 93 octane fuel. It's possible that your file was built for a lower octane fuel, but I suspect you should still be seeing more than 0.8 bar. Also, not sure about your fuel consumption level either. If it's much less than others are getting, you probably are running rich. It may in fact be that you have a weak waste gate spring or one (or both) waste gates are out of adjustment.
I'd probably give Mark Hatfield at FVD a call and let him know what's going on. His number is 800-274-2220 (extension 27 I think).
R-
Bill
Old Jun 17, 2010 | 11:20 PM
TTurbRon's Avatar
TTurbRon is a jewel in the roughTTurbRon is a jewel in the roughTTurbRon is a jewel in the roughTTurbRon is a jewel in the rough
I too am only getting .8 bar also. K16s, psi (orton) exhaust with gutted cats, k&n drop in and haven't upgraded my diverters yet but I don't think that is the problem. How do I tighten my wastegates? Thanks in advance. -Ron P.S before the tune I would get .8-.9 on a completely stock car with just straight pipes.
Old Jun 18, 2010 | 01:35 AM
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
Waste gates need to be adjusted in about 5-7 turns on both sides. You will get 1.0 bar right away and see 1.1 in higjer ears. I am runing a Revo flash with K24's and tightened my waste gates and get 1.2 bar. I have been runing them like this for two years and 5700 miles with no issues.
Old Jul 12, 2010 | 11:16 AM
TTurbRon's Avatar
Tightened down my waste gates 2 turns on each one and I'm getting .9 in lower gears and seeing a solid 1.0 in fourth. Still running stock diverters too. But man do my turbos spool so much faster now at lower rpm.
Old Jul 13, 2010 | 09:59 PM
I tightened 2 turns on each side .i can see 0.9 on 2nd gear,1.1 on 3rd and 1.2 bar on 4th and fifth gear.
