Quick and simple question for the gt2 owners
Old Feb 16, 2010 | 11:10 AM
PrecisionPorsch's Avatar
PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !
Are your rear fenders rolled from the factory? Thanks!
Edwin
Old Feb 16, 2010 | 02:28 PM
landjet's Avatar
I don't have a GT2 but remember reading that the rear fenders are rolled from the factory. I'm sure it has to do with the 12" wide rear wheels.
Old Feb 16, 2010 | 02:42 PM
TwinT's Avatar
TwinT is infamous around these parts
Yes.
I did have 12" GT2 wheels on my 996tt also without issue.
Old Feb 16, 2010 | 02:46 PM
PAULIEWALNUTS's Avatar
PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !
Yes they are
Old Feb 16, 2010 | 03:15 PM
80shilling's Avatar
80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !
Yes.. Rolled from the factory..
Old Feb 16, 2010 | 03:22 PM
Thanks guys... Much appreciated. I guess that means I need to roll mine too.
Edwin
Old Feb 16, 2010 | 05:37 PM
jamie furman's Avatar
jamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond repute
Edwin
Why do you have to roll yours too?
Old Feb 16, 2010 | 05:40 PM
He has a Turbo not a GT2.
Old Feb 16, 2010 | 06:07 PM
Like Paulie said, I have a 01 turbo and I am getting wheels made that sit very flush with a gt2 so I'll need to roll the fenders in order for them to fit.
Edwin
Old Feb 16, 2010 | 06:18 PM
Twin T said he has GT2 Wheels on his TT with no issues without rolling them, and I just put my GT2 wheels on my TT that I am taking to TPC to have set up for RR and they told me that I might not need to have the rear fenders rolled when lowered because of the camber and such. If I do have to have the fenders rolled who would do something like that without dinging up the fenders.
Old Feb 17, 2010 | 01:03 AM
Turbo Fanatic's Avatar
I had stock GT2 wheels and tires with 7mm spacers in the rear no rubbing at all with rolled fenders.
I rolled my own fenders by applying 3 layers of duct tape on the striking end of a 2lb mallet to protect the paint and beat the inner lips back gently. No paint chips or dents, took 5 minutes each side. It's simpler and less risky than you might think. 4 years later, it's still perfect.
Rolling the rear fenders opens a good 1/2". The fronts are factory rolled on all widebody 996 cars and can take MUCH wider setups than you might think. The only issue is that taking the front wheels out too far begins to rub the inner fender liners at about 50% lock and can wear a hole in them (right behind the radiators) or worse start a fire. A heat gun can help you push back the liner a bit and open space permanently.
I run 15mm spacers on champion 11.5" rear wheels and 315/25-19s... it's a nice fit with ZERO rubbing.
Old Feb 17, 2010 | 01:30 AM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
Edwin
Really no big deal. A good shop can do it for not alot of $$$ without risk to the paint work
Perkman87
Nov 19, 2015 05:31 PM
SharkyShark20
Sep 19, 2015 09:54 PM
turbotuner20v
Sep 11, 2015 12:02 PM
