996TT exhaust vs 996 GT2 exhaust
Old Feb 16, 2010 | 11:49 PM
ryancr500's Avatar
ryancr500 is infamous around these parts
Would there be any advange to using a 2003 Porsche GT2 exhaust on a 2001 996 TT? What are the differences in the stock exhaust systems?
Ryan
Old Feb 17, 2010 | 12:16 AM
Turbo Fanatic's Avatar
Same.
Old Feb 17, 2010 | 01:54 AM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
Are the factory headers the same?
Old Feb 17, 2010 | 05:36 AM
Prche951's Avatar
all the same. I heard the GT2 IC's are a realistic 2-4% improvement
Old Feb 17, 2010 | 06:36 AM
jamie furman's Avatar
jamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond repute
Originally Posted by ari
Same.
I was told by TPC that the GT2 and X50 exhausts were not the same as the regular turbo and were superior to the regular turbo exhausts.
Old Feb 17, 2010 | 10:07 AM
winnigt2's Avatar
winnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond repute
X50 and GT2 exhausts are the same..... stock tt muffler is different but not worth to change it....(GT2/X50 have a greater holes inside the muffler but same cats...no real improvement) headers are the same on GT2/X50 and stock TT
Old Feb 17, 2010 | 10:20 AM
Prche951's Avatar
I guess the big question is, how good are the factory cats. Can they be used as part of a free flowing exhaust or are they so restrictive that it is not worth it. Does anyone know if they are 200,300,400 etc cel cats?
Old Feb 17, 2010 | 11:22 AM
winnigt2's Avatar
the factory cats are 400.....two cats on every side....this cats are a great restriction imho
Old Feb 17, 2010 | 11:26 AM
Prche951's Avatar
two cats on each side? My factory exhaust only has one on each side. There is barely enough room for one much less two on one side. so each individual unit is 400 cel then?
Old Feb 17, 2010 | 12:07 PM
winnigt2's Avatar
every factory muffler have two cats on every side...first cat direct after the turbos...second cat after the second oxygensensor...if you remove the second oxygensensor you can see a great diameter second cat ....heavy and great...if you remove this two cats and use one 100cell on every side on a factory muffler you have a improvement...but work and material cost a lot and the better way is a aftermarket muffler for my understanding
The oem cats are restrictive
Old Feb 17, 2010 | 12:25 PM
Prche951's Avatar
interesting. I never noticed that. I will look at my factory exhaust tonight.
Old Feb 17, 2010 | 12:54 PM
Hogapalooza's Avatar
Hogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond repute
Yep 2 cats. A 200 then a 400 cat I believe then the open area that the tube you see out the back snakes through. Look up the thread about the TJW mod I believe it is called. It has a great cut away pic of a stock oem muffler
Old Feb 17, 2010 | 12:57 PM
stef@europipe's Avatar
stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !
The stock 996 TT / X50 / GT2 cats are 300 cpsi not 400 cpsi.
cpsi = cells per square inch
So with the 300 cpsi cats there are about 17.5 cells per inch.
17.5 cells / inch x 17.5 cells / inch = 306 cells per square inch.
The stock cats of the 964 , 993 Carrera , 993 Turbo , 996 Carrera , 996 GT3 all have 300 cpsi.
Old Feb 17, 2010 | 01:02 PM
Thanks for the clarification.
Old Feb 17, 2010 | 01:05 PM
Prche951's Avatar
excellent information from everyone.
