996tt fuel system: how it works and it's limits
Old Feb 26, 2010 | 03:38 PM
The fuel cooler just to the right of the Y pipe will drop fuel pressure at the rails... it did on mine... so we by pass it.
markski
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Feb 26, 2010 | 04:29 PM
ReeknHavic's Avatar
ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !
Very good and informative post. I got a good out of the "CREATURE". A close up of that thing in dim lighting would make for a good movie monster.
Old Feb 27, 2010 | 05:45 AM
Mikelly's Avatar
Martin, Thanks for taking the time to actually SHOW where the restrictions are and what you see from the mock test. Sure we "knew" this a while ago, but I have yet to see anyone else "SHOW" me "what" was happening, with measured and accurate data.
Bravo!!! BRAVO!!!!
Mike Kelly
Old Feb 27, 2010 | 01:02 PM
x50plt's Avatar
x50plt is a splendid one to beholdx50plt is a splendid one to beholdx50plt is a splendid one to beholdx50plt is a splendid one to beholdx50plt is a splendid one to beholdx50plt is a splendid one to beholdx50plt is a splendid one to behold
fuel cooler
markski
I talked to Todd about this and he did not advise by passing it. He said the tank would overheat. Much hotter in Ca and Az then Chicago. oh Marek thanks for all the tech support, the car is running great. Your intercoolers worked out awesome. thanks Greg
Old Feb 27, 2010 | 01:10 PM
BLKMGK's Avatar
Outside temp isn't the issue with fuel tank heating - circulating the fuel round and round through a high pressure pump is where the heat comes from. I've not seen this fuel cooler so I'm not familiar with it - how exactly does it work?
Old Feb 27, 2010 | 01:50 PM
x50plt's Avatar
fuel cooler
The fuel cooler is mounted on the suction line of the a/c unit. It must have a sensor that turns on the a/c compressor as needed, then it must turn on the heat to compensate for the unwanted cooling inside. german engineeering.
Old Feb 27, 2010 | 01:59 PM
emadelta86's Avatar
emadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond repute
That's what I call R&D...Great job.
Old Feb 27, 2010 | 02:31 PM
Looks like Todd took care of you...
thanks for the kind words.
mark
9.66
click to view
Old Feb 27, 2010 | 06:40 PM
justinn's Avatar
justinn is a splendid one to beholdjustinn is a splendid one to beholdjustinn is a splendid one to beholdjustinn is a splendid one to beholdjustinn is a splendid one to beholdjustinn is a splendid one to beholdjustinn is a splendid one to behold
Keep in mind that the jet system has certain requirements to be able to siphon the legs of the tank to the built in sump. It cannot be bypassed or you will only be able to use 1/2 of your fuel tank The top half
Justin
Old Feb 27, 2010 | 07:47 PM
x50plt's Avatar
pump
Has anybody tried running a seperate smaller pump to take care of the in tank spray duties?
Old Mar 31, 2010 | 10:12 PM
I respectfully disagree that running a second fuel pump the way we do on stock pressure can be devastating. Protomotive has probably done a few hundred of these over the last 6 years or so and it works very well. We put down 750 rwhp on our basic second pump in series. Many members here have this set up. I have never heard anyone here have catastrophic engine failure do to a a poorly designed 2nd pump approach. I'm not saying it's the best nor the only way but it works very well on our set ups.
I have a dual parallel set up on my car as a few other 1000 rwhp cars do here on 6speed.
Not discrediting any new finding at all but just stating known facts.
Mark
9.66
click to view
Old Apr 1, 2010 | 08:56 AM
Tony@epl's Avatar
Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !
Mark
I have how ever had no less then 2 cars come through the shop, that the customer didnt know their inline pump was dead. This is the main reason we dont do the inline set up like this anymore, you wont know if 1 pump is weak or dying untill its too late.
Old Apr 1, 2010 | 09:31 AM
SSMugen's Avatar
SSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond repute
Perhaps there is a way to meter this?
Old Apr 1, 2010 | 09:42 AM
unvmy996's Avatar
Ive had the secondary pump for about 3 yrs , first with my 18gs and now pushing my 30r's , i have never had an issue and quite frankly there are 100s of these setups around and i , personaly have not seen or heard of any issues, thing is i think that some people on here are trying to discredit this setup for some reason......
so its cool and all that you you guys did that the fishtank tests , but real world results speak for them selves .
Old Apr 1, 2010 | 09:46 AM
BigBadBen's Avatar
BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !
From my first hand experience I would ALWAYS do dual parallel pumps!
Yes it costs more money but without proper fuel delivery under every situation you are asking for trouble. Why risk your motor for $2-3K extra for a parallel system.
If you want more and more power, do it right the first time and then forget about it. Thats my two cents
This is the safest solution period!
