White turbo blades
Old Mar 1, 2010 | 07:42 PM
Mpsuk's Avatar
Mpsuk is infamous around these parts
White turbo blades
I recently swapped the exhaust on my car and noticed on one of the turbo the blades were white, what could this be? If i can work out how ill post a picture from my phone. Also i think my actuaters are sticky, any ideas?
Old Mar 1, 2010 | 07:44 PM
Mpsuk's Avatar
Old Mar 1, 2010 | 08:15 PM
ant_8u's Avatar
ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !
Can't see picture
Add it to a Photobucket account then paste the link here
Old Mar 2, 2010 | 06:46 AM
Mpsuk's Avatar
Thumbs up
Any ideas??
Old Mar 2, 2010 | 07:52 AM
ttboost's Avatar
Still can't see the picture. Do you always run pump gas? Race gas will sometimes leave that evidence too, but not on only one side. It may be a sign that that bank is running a little lean?
Old Mar 2, 2010 | 09:13 AM
ant_8u's Avatar
Agreed it could be a lean mixture
Has the car been flashed? That could effect timing
Are the injectors working properly?
What fuel are you using?
Is their a leak which is drawing unmetered air into the engine?
Old Mar 2, 2010 | 02:42 PM
Mpsuk's Avatar
No idea, when we swapped exhaust we noticed a leak by os intercooler and fixed it, also had a slight misfire but have swappedplugs, may need to swap coilpacks, i cant work out how to post the picture as im accessing internet on my iphone. Do any of you know how to set pressure on actuators? My bro said they wernt very tight and i am struggling in first few gears to get 1 bar. Also occasionaly itshows 1.4 - 1.5 bar for a split second which leads me to believe actuators are shot. Any advice will be appreciated thanks
Old Mar 2, 2010 | 02:51 PM
David C's Avatar
David C is a name known to allDavid C is a name known to allDavid C is a name known to allDavid C is a name known to allDavid C is a name known to allDavid C is a name known to all
White deposit or corrosion?
Old Mar 2, 2010 | 02:57 PM
Mpsuk's Avatar
On one side their is a white deposit covering the blades all over, on the other side their is some evidence of the same but lots less, also their is notable corrosion to the actuators
Old Mar 2, 2010 | 02:59 PM
ant_8u's Avatar
Download the photobucket app for your iPhone, then you can add photos
A standard car should only be 0.7bar
1.4bar sounds high even for a spike
If you're seeing that on the boost gauge and it's holding there you might want to try moving your actuators to make sure they're not stuck
What did your brother check when he said they were loose?
Old Mar 2, 2010 | 04:33 PM
Mpsuk's Avatar
Car is flashed, should run 1.0 - 1.1 bar but in first three gears only manages 0.9. The boost spikes are rare but usually happen on hard acceleration in 1st or 2nd gear. My bro said he could move the actuaters easily with his fingers and said they were heavily corroded so may not open quickly enough occasionaly and may prematurely leak boost if not tight enough. In future im thinking of going k2420g so think a 1 bar actuator swap may be a waste. Any ideas?
Old Mar 2, 2010 | 05:06 PM
Janker's Avatar
Janker is just really niceJanker is just really niceJanker is just really niceJanker is just really nice
Your not to far away from me & Ant (Midlands) - perhaps we could meet up for a cuppa and a look
We all need to go for a hoon some day soon..
Jim
Old Mar 2, 2010 | 05:13 PM
ant_8u's Avatar
Jim
Yes Indeed
EDIT - Jim, is that the new addition in your avatar?
Old Mar 2, 2010 | 05:21 PM
RoadSpike's Avatar
RoadSpike is infamous around these parts
Do they happen to look like this?
Old Mar 2, 2010 | 05:28 PM
yllwturbo's Avatar
yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !
so thats where i left my money!!!!!!!!!! been looking for it for a couple of days now. could u please sent it to me. pm me for my new address...lol
