Split Rim Refurbishment.....Perimeter Bolts
Old Mar 7, 2010 | 05:30 PM
XwalkerX's Avatar
XwalkerX has much to be proud ofXwalkerX has much to be proud ofXwalkerX has much to be proud ofXwalkerX has much to be proud ofXwalkerX has much to be proud ofXwalkerX has much to be proud ofXwalkerX has much to be proud ofXwalkerX has much to be proud of
any place to source bolts/backings, lips, torque specs, are the bolts alrite to reuse?
are these a true 3 piece?
Old Mar 7, 2010 | 06:10 PM
ant_8u's Avatar
ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !
That's the info I don't have
I have emailed the manufacturer, I'll let you know when they reply
What does the etching say on your rims?
Does it say "Speedline for Porsche" or "TechArt by Speedline" ?
I don't think the TechArt etching is available anymore
The "Speedline for Porche" are still available, but there's a slight difference - Speedline is written in upper case on the original rims, but on the replacement ones the "i" in Speedline is lower case - other than that they're the same
I'll see if I can find the name of the stockist for you
They are true three piece wheels
The perimeter bolts are rated as 10.9 strength
Minimum Tensile Strength is 150,000psi
Tensile strength is the maximum load in tension (pulling apart) which a material can withstand before breaking or fracturing.
Minimum Yield Strength is 130,000psi
Yield strength is the maximum load at which a material exhibits a specific permanent deformation
Minimum Proof Load is 120,000psi
Proof load is an axial tensile load which the product must withstand without evidence of any permanent set
Old Mar 7, 2010 | 06:25 PM
ant_8u's Avatar
I 'think' the bolts are M7x37, but have heard others mention 35mm before
EDIT - Forgot to add, the bolts are torqued down to 15-20lbs
Old Mar 7, 2010 | 10:48 PM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
I had the same wheels on my 993. They came standard on the 1995-993RS and they where built for Porsche by Speedline and they are rare as they were only sold for one year. If I recall they had a laser etched outer barrels "Speedline for Porsche". Speedline also marketed the wheels directly but I believe they were heavier than the Porsche versions and were produced for several years. I don't know about the Techart versions. What I didn't like about them was they were a 17" center with the extended barrels used to increase the overall diameter to 18". I sold them due to both the weight and looks issue. Before you spend any money on them, have them spun to make sure the inner and outer barrels are true. Replacing just the hardware is about $400 labor plus the cost of new hardware. If you have to replace all the barrels, you could be looking at $2k. This is not the simply DYI job you might think. It takes a certain amount of experience to reassemble the wheels to keep them true and balanced.
Old Mar 7, 2010 | 11:00 PM
ant_8u's Avatar
Thanks Duane
The labour cost is not an issue as I will be doing the majority of it myself
I've rebuilt a few split rims now
The thing I'm trying to find out is if the original bolts are still available (incase I snap any) or if i'd need to replace the lot
Old Mar 8, 2010 | 06:06 AM
ant_8u's Avatar
Ok, I have received a reply from Speedline UK saying Speedline Italy will not provide any parts for Split Rims
They said I could always try contacting Porsche??
Hopefully I'll get a different reply from Speedline Italy
Old Mar 8, 2010 | 06:16 AM
ant_8u's Avatar
Neil - I emailed Mike
He said £145ea to do the whole job
Or £125ea if I completely strip them myself
Old Mar 8, 2010 | 12:55 PM
Szpet's Avatar
Szpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud of
I have sent you a PM with the source where you can get the parts.
Old Mar 8, 2010 | 01:08 PM
ant_8u's Avatar
Received - Thanks
Yes, I have used them before
I was hoping to either replate or replace my perimiter bolts for genuine speedline items but it looks like I might not have that option
If I snap any I'll be using the guys you mentioned again
keeperofbeasts
11
Apr 3, 2017 10:53 AM
Staff@WORLD
Feb 8, 2016 09:22 AM
JSF721
Detailing
Sep 8, 2015 07:57 AM
iammulva
Sep 7, 2015 03:11 PM
manfred@loma_wheels
Sep 2, 2015 11:22 AM
