new wheels/tires don't fit cuz of protruding IC piping :(
Old Mar 10, 2010 | 11:29 PM
  #31
GTstreet996's Avatar
GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !
Originally Posted by flash68
Yes they did for the 4 minutes they were on the car! Now I am on my 3rd set of wheels/tires on the car in 24 hrs.
Thanks Mike, but yes I can tell you clearly have more space there. I wonder why 911GT700 has the same stuff but similar issues as mine?
Invoice from tire rack says:
18x8.5 ET53
18x12 ET51
I just ordered fitment for 996TT after seeing them on Graham's car (a GT2).
Contacted HRE and they said my offset is 48 18/8.5 and 45 18/11.5
Old Mar 11, 2010 | 02:38 AM
  #32
flash68's Avatar
flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !
Originally Posted by MBailey
Cant imagine why? Are your wheels 18s or 19s?
My new OZs are 18x12 on 315/30/18, and old HREs were 18x11.5 on 315/25/19.
Originally Posted by 911GT700
To be honest a little worried about rolling but might have to because of the non aggressive offset . I'm also going to the custom hard pipe.
I will post some pics tomorrow Dave. It looks very similar to yours!!
Cool, yes please post your pics to compare. Why worried about fender rolling. We might do that on mine too.
Originally Posted by Mad Ness
"I" indicates the hub face. figures on either side are inches from hub to rim only edge. 315 over 295 - tires are 0.4" wider on either side in addition. Note these are rough indications only as manufacturers side wall or tread designs affect actual widths/clearance. Just use as guideline, then trial and error.
Stock 7.3" I 3.7"
New 8" I 4"
The new rim only is only 0.7" closer to the inner wheel well wall. The 315 tires are about 0.4" wider on each side over stock. I believe diameter increased as well (30 over 315 vs 30 over 295). So together that's 1.1" decreased clearance, diameter increase not factored in.
Put the car down, gauge how much further outwards (away from car), the wheel can be shifted with out causing issues on the fender side. That should indicate max. spacer size. The additional increase from both offset and width (both wheel/tire) is net 1.1" and thus from crude back of envelope calculations, would require a roughly 28mm spacer to line back as stock. Note, the new rim/tire is already 0.7" closer to outside fender.
Just did these calculations quickly so please just use as additional info only and check it.
FYI just in case that hasnt been factored in. i believe the front/rear over all diameter ratio has to be with in a certain range for the AWD to function properly. I can't remember what that range is.
That is some serious back of the envelope math. Thanks for that. Depending on how much we can move the piping, I may then try a spacer or not. It looks like I can move the wheels/tires out a bit and still be okay.
Thanks everyone for the help. And thanks to Kenny (you stalker!) for lending me the turbo twists and tires today!
Old Mar 11, 2010 | 06:08 AM
  #33
MBailey's Avatar
Dave, I am not an expert on this tire/wheel size/offset topic but the only parameter where you are currently larger between your new setup, your old setup, and my setup is the width of your new rear wheel. I have an 18x11 rear HRE. You had a 19x11.5 that worked. Perhaps that last half inch of wheel with a bigger tire is a little too much?
Old Mar 11, 2010 | 12:06 PM
  #34
flash68's Avatar
Could very well be part of the issue but not all of it. But just doing a measurement of what a standard 315/25/19 tire vs a 315/30/18, the 18 is about 1/4" taller in diameter, and then you have varying manufacturer actual diameters as is widely known. I mean I looked at the clearance on both sides right before and right after and the front to back clearance (not the offset or side to side clearance) was hugely different, so either way we have to move that IC piping back somehow, whether its via tilting the ICs and tweaking the brackets or going with a custom hard pipe.
I am thinking custom hard pipe now as that should also help alleviate the boost leaks I have been getting too often on this setup.
I wonder if these 3.5" Proto ICs are greatly different dimensions than the same sized EVOMS ICs... or are the hose connection points in slightly different locations? I dunno...
Old Mar 12, 2010 | 01:36 PM
  #35
flash68's Avatar
Took the wheels and plastic flaps off last night and had a look.. decided to go the custom hard pipe route to try to get back to near stock location and no inteference. It ain't pretty but here is what I had going on..
passenger side
driver side
Old Mar 16, 2010 | 02:12 AM
  #36
flash68's Avatar
Started a new thread here with new piping done and more clearance issues for those interested...
https://www.6speedonline.com/forums/...ml#post2764885
joseph_number1
Jul 19, 2018 05:45 PM
John@SpeedTech
Aug 23, 2015 12:07 AM
Fabspeed Motorsport
Audi
Aug 21, 2015 11:30 AM
ppwchiang
Aug 20, 2015 10:28 AM
HolmaN
Aug 18, 2015 01:35 PM
