Subtle hesitation at highway speeds. Any idea?
Old Mar 14, 2010 | 12:39 PM
S4Drifter's Avatar
S4Drifter is infamous around these parts
So here's the issue. While maintaining steady throttle at around 70mph I occasionally noticed a little hesitation in the engine, a minor stutter followed by a resumption of speed. I noticed this too with the cruise control on, but not as often. Its almost as if I let off the gas pedal ever so slightly. Around town and city driving I do not notice it, but thats probably because the throttle is all over the place. Any ideas?
I just had the car in for major service (figured I would start ownership off right) and as part of it, had all the fluids, sparks and DVs changed. It was doing this before the service too, but thought the service would take care of it.
Could it be as simple as a clogged fuel filter or something like that? I appreciate any insight. Car has 50k on it and is an x50 if that matters. Thanks in advance for your help.
-Kirk
Old Mar 14, 2010 | 12:47 PM
ard's Avatar
ard
What RPM?
Coilpacks replaced with plugs?
Old Mar 14, 2010 | 01:04 PM
S4Drifter's Avatar
Probably around 3k RPMs 5th Gear. Coil packs were not replaced with plugs. Was that a big no-no on my part? Expensive fix? Here I thought I was being proactive by changing the Flueids, Dvs and F hose. Sigh....
Old Mar 14, 2010 | 01:44 PM
raineycd's Avatar
Might be the variocam kicking in and out. Kinda feels like a hesitation, but not... Usually does it around 3k rpm.
Old Mar 14, 2010 | 02:37 PM
-Kirk
did all that started after you changed the above or its been like that?
you answer this question and you will know where to start looking...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Mar 14, 2010 | 04:14 PM
ait109's Avatar
ait109 has a brilliant futureait109 has a brilliant futureait109 has a brilliant futureait109 has a brilliant futureait109 has a brilliant futureait109 has a brilliant futureait109 has a brilliant futureait109 has a brilliant futureait109 has a brilliant futureait109 has a brilliant futureait109 has a brilliant future
+1 This is normal.
Ed
vchris
Cayenne Turbo
Sep 11, 2015 02:52 PM
ECS Tuning - VW
Sep 11, 2015 12:57 PM
GSP
Sep 9, 2015 05:31 AM
markj
Sep 6, 2015 09:08 AM
