A Friendly Reminder!
Old Jan 8, 2005 | 12:40 PM
20C4S's Avatar
as a fellow board member just recently blew one of his rear tire due to the inner side wall completely worn out, please take few minutes go the the car bend over & check the rear tire. THIS IS FOR YOUR OWN SAFETY.
we all have at least +1 degree nagative camber in the rear of our cars for better handling reason. therefore the inside will wear out a lot faster than the outside & u can't see it. this is very common & please don't freak out. rear tire will probably have about half life as front & should have no more than 10k miles.
again, u don't want the tire to blow out when u go 80+ mph. so please go check the tire & have a safe drive!
Old Jan 8, 2005 | 12:51 PM
996turbo's Avatar
996turbo is infamous around these parts
thanks for the heads up Arling.
Old Jan 8, 2005 | 01:00 PM
MANA's Avatar
MANA is infamous around these parts
Old Jan 8, 2005 | 01:29 PM
it happened to me already once....
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jan 8, 2005 | 03:48 PM
OKHJOON190's Avatar
OKHJOON190 is infamous around these parts
thats my car arling is talking about ... i was lucky that i wasnt speeding on the freeway when this happened ... thanks for your help Arling, if it wasn't for your help i would probably still be waiting for porsche roadside assistance ... did everyone know that porsche roadside assistance will only tow your car, and will not change the tire? i had a friend bring me a back tire with rim, and roadside assistance would not send someone to put it on. i had to take my friends car and go out looking for a tow truck because roadside service told me that it would take another 2 hours to send someone out (to tow my car), and i didnt have a jack for my car. i ended up getting lucky and finding a tow truck in 10 minutes and paying the guy to switch the rim for me.
Old Jan 9, 2005 | 02:13 AM
HotRodGuy's Avatar
Great advice, I eat tires up on my Acura, i've had a few very suprising tire rotations that have luckily caught some near misses.
Old Jan 9, 2005 | 03:19 AM
B7R's Avatar
B7R
B7R has a spectacular aura aboutB7R has a spectacular aura aboutB7R has a spectacular aura about
Many Thanks for your "Valuable" advice.
Old Jan 9, 2005 | 09:14 AM
damon@tirerack's Avatar
Moderator
This is also the case for almost any european performance sedan, too.
Almost all of these cars eat tires on the inside faster. Some manufacturers of tires are starting to make them with harder inside halves (PS2) to try and combat uneven wear.
Please take the time to check. It's always a good bet too to get in the habit of having the tires dismounted from the rims at least once during their lives and moved to the other side of the car and re-mounted. This will help keep them wearing evenly.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Jan 9, 2005 | 12:03 PM
trojanman's Avatar
Welcome to the OC, bitch!
trojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant future
Happened to me several months back. Luckily I wasn't going terribly fast.
On the plus side, I learned how to change a spare tire.
Old Jan 9, 2005 | 12:17 PM
collin996tt's Avatar
Senior Member
collin996tt is infamous around these parts
happened to me too. i was going 80. the car was totally neutral after the rear blowout. i was able to limp home a mile away without damage to rim or car.
Old Jan 17, 2005 | 01:25 PM
45otto's Avatar
Kills Bugs Fast
45otto is infamous around these parts
Thanks for the heads up.....sure enough cords on the inside. Replacements ordered up.
Old Jan 17, 2005 | 01:31 PM
Zippy's Avatar
How is the inside getting eaten faster. I know if soneone drives in a straight line for 10K miles the negative camber will errode the inner edge, but as soon as you start pushiong it through corners, that is quickly reversed and the outer edge wears MUCH asfter than the inner edge. Does the 3 - 5 auto cross events and mabey 1 or 2 annual track days that I participate in make that much difference?
FUTURESTAR
BMW //M
Nov 18, 2015 10:37 PM
007 Vantage
Oct 8, 2015 08:35 PM
flewis763
Oct 4, 2015 04:14 PM
